This is a modification for my last posts. After consultations with my department and seniors I have decided to do a project of constructing an 8051 trainer kit. I am thinking of incorporating microcontroller interface with 8255 programmable ports, LCD, LED dispalys, keyboard for data input by user and interface with a computer. It will also have a programmer on board and a switch to choose between programming and running mode. When in programming mode we should be able to burn our program to the onboard microcontroller through the PC and when in running mode, the board will run the program in the microcontroller, with hte user being able to see the output on the onboard LCD or LED display units. It will also have an onboard keyboard for user to enter data to it. I also need a feature such that this data input may be done automatically by the computer, with the outputs of the microcontroller being stored in the computer rather than being displayed on the onboard LCD or LEDs.
Does anybody have any ideas?
I will be extremely greatful for your help.
Please guide me to any other useful websites as well.
Thank you.
PS: The most easily available 8051 microcontroller varients in our market are :
89c51
89s51
89s52
(All by Atmel)
Others are not easily available so I will probably be using one of the microcontroller series mentioned above.
use P89V51RD2 so that you can program it directly through the com port using Flash Magic software.
also P89V51RD2 is very easily available in the market, though its costlier than 8951/52 but have more program memory and RAM and you just require MAX 232 for programming it.
