Please!!!Help on Hamming code(15,11) error detection
nego
Newbie level 6
Newbie level 6
Hi, may i know is it possible for us to detect the position of multiple errors in the Hamming code(15,11) using the method of parity bits.
Example:
The original transmitted hamming code is 100111010101111 but the received code is 111111011101111. SHOW how the parity bits indicate the position of the errors in the code.
Can anyone help? I unable to find back the position of the errors.
Correction capability of this code is only a single bit.
In your example there are 3 bits in error.
If the received word is a code word, the decoder does not correct any bit;
otherwise, it corrects a single bit giving the nearest (in Hemming distance) code word.
Regards
Z
Regards
Z
Okay, noted. Then how about detecting the positions of error bit?? Is there any method to detect the position in the code? Thanks :)
Of course.
Please refer to bibliography. Not necessarily at books specifically devoted to error correcting codes. Almost all books about digital communications contain at least a chapter about the subject.
Regards
Z
