The voltage driving the capacitive voltage divider would be an AC voltage, the varicap has rather low capacitance, some ten to maximum 100 or 200 pF. So you are building a high frequency circuit which can't drive an ADC without further signal processing, e.g. rectifying. It's much easier to make a variable frequency RC oscillator and count the frequency.I need to use the variable capacitor to the same effect (modify voltage over range for my ADC). SO I was thinking of connecting another cap in series with it, applying a voltage and thereby forming a voltage divider with which to feed my ADC. AS the capacitance of the variable capacitor changes, so should the voltage at the point between the capacitors.
Capacitors do not conduct DC voltages so it would not work as you intend. The other factor is that if you add series capacitors the overall effect is to reduce the total so the existing tuining would no longer work either.
Brian.
