please help me understand this waveform
high voltage
Junior Member level 1
this supposed to be an output voltage ripple of a flyback converter..
can u help me understand the mentioned points in the waveform ??
thanx in advance
Hello high voltage,
where do you measure the two waveforms?
Channel 1 looks like the unfiltered voltage after rectifier and Channel 2 the filtered voltage.
Can you give the circuit.
Regards
Rainer
i think you are watched it on the dso
the peak voltage on channel1 and channel2 are indicated over there that is the voltage of your out put
LaTeX Commands Quick-Menu:
