Please tell me how to remove pads from GBS and GTS layers.
The goal is to create viases that look like a common hole. No solder mask over them.
Many thanks!
The mask layers are negative layers - whatever you see on those layers is a void (a hole in the mask).
For your vias, there are a couple of ways to approach the problem. In the via dialog (double click on the via), you have a choice to either let the mask expansion design rule determine the size of the opening, or you can override the rule. The second way would be to just draw the opening you want on the mask layers using lines, arcs, fills, etc.
Hello,
Please help me to solve this issue in PCB files: I cannot select any component on the board. I can only select the primitives (polygons, tracks, etc). In fact, it's like Altium doesn't recognize components' bodies anymore.
First, hit the "Clear" button at the lower right corner of your PCB Editor workspace to clear any masks that might be set. Then try unchecking the box in "Preferences>>PCB Editor>>General>>Protect Locked Objects".
If that doesn't do it, look to see if the box is checked for "Preferences>>PCB Editor>>General>>Shift Click to Select". If it is, click on the button marked "Primitives...", and make sure that the "Components" box is checked.
If that doesn't do it, check to see if all your components are locked by using the PCBFilter Panel with a query like "IsComponent And (Locked = True)". You can then unlock all of the selected components from the "Graphical" section of the Inspector Panel.
Thank you for your quick reply!
The first two cases are not relevant, and the the third give me this message: «Access violation at address 1C8472E2 in module 'ADVPCB.DLL'. Read of address 00000000 at 1C8472E2.» In fact, I had to deal with this message since I encountered the problem. I've tried the file on other pc and the result was identical.
... Later edit:
After restoring my win system, pcb filter worked fine.
Many thanks house_cat
