shifa.aju
Newbie level 2
- Joined
- Feb 2, 2015
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 34
Code dot - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 close all; clear all; clc; n1=1; n2=14; FFT_SIZE=256; %CP=16; conv_in=[]; %% Data Generator Data_gen = randint(1,11,255) Data_IN=dec2bin(Data_gen); s=0; %% BER PARAMETERS EbNo=0:1:15; BER = zeros(1,length(EbNo)); numPackets=15; frmLen = 1000; for idx = 1: length(EbNo) for packetidx = 1 : numPackets %% Convolution Encoder conv_in=[]; for index =1:11 conv_in=[conv_in double(Data_IN(index,:))-48]; end conv_in=[conv_in 0 0 0 0 0 0 0 0]; %%8 bits padding DIN=conv_in; trel = poly2trellis(7, [171 133]); % Define trellis. code = convenc(conv_in,trel); inter_out=code; %% BPSK Data Mapping mapper_out=mapping(inter_out',1,1); clear inter_out; D=mapper_out; %% CDMA TRANSMITTER % encode bits and transmit % CDMA specific parameters C = [ -1 1 -1 1 ]; % code for the user which will be multiplied %with data stream of the user#1 i.e.mapper_out M = length(C); % length (number of bits) of code Y = size(mapper_out); N = Y(1); % number of unique senders / bit streams I = Y(2); % number of bits per stream T = []; % sum of all transmitted and encoded data on channel RECON = []; % vector of reconstructed bits at receiver G = zeros(I,M); for n = 1:N Z = zeros(I,M); for i = 1:I for m = 1:M Z(i,m) = [D(n,i)*C(n,m)]; end end G = G + Z; %G is the data to be transmitted after IFFT end ifft_in=zeros(256,4); for i=1:4 ifft_in(:,i)=[0;G(1:96,i);zeros(32,1);zeros(31,1);G(97:192,i)]; end for i=1:4 tx_data(:,i)=ifft(ifft_in(:,i)); end clear ifft_in; %% Passing the data through AWGN channel rx_data=zeros(256,4); rx_data1=zeros(192,4); for i=1:4 rx_data(:,i)=awgn(tx_data(:,i)./sqrt(16),EbNo(idx),'measured'); end for i=1:4 rx_data(:,i)=awgn(rx_data(:,i)./sqrt(16),EbNo(idx),'measured'); end for i=1:4 rx_data(:,i)=awgn(rx_data(:,i)./sqrt(16),EbNo(idx),'measured'); end %% OFCDM RECEIVER PART: %% Taking FFT of the noisy data after reception clear tx_data; for i=1:4 rx_data(:,i)=fft(rx_data(:,i)); end for i=1:4 rx_data1(:,i)=[rx_data(2:97,i); rx_data(161:256,i)]; % taking out user#1 symbols for despreading end G=rx_data1; %% CDMA RECEIVER for n = 1:N TOT = zeros(1,I); R = zeros(I,M); for i = 1:I for m = 1:M R(i,m) = G(i,m) * C (n,m); TOT(i) = TOT(i) + R (i,m); end end RECON = [RECON ; TOT / M]; end RECON rx_data1=RECON; Demap_out=demapper(rx_data1,1,1); %%viterbi decoder vit_out=vitdec(Demap_out,trel,7,'trunc','hard'); DOUT=vit_out [number,ratio] = biterr(DIN,vit_out); error(packetidx) = biterr(DIN,vit_out); end % End of for loop for numPackets BER21(idx) = sum(error)/(log2(4)*numPackets*frmLen); end h=gcf;clf(h); grid on; hold on; set(gca,'yscale','log','xlim',[EbNo(1), EbNo(end)],'ylim',[0 1]); xlabel('Eb/No (dB)'); ylabel('BER'); set(h,'NumberTitle','off'); set(h,'Name','BER Results'); set(h, 'renderer', 'zbuffer'); title('OFCDM BER PLOTS'); semilogy(EbNo(1:end),BER21(1:end),'b-*');
