Please Help me on Blinking LED Project. (MicroC and ISIS)
Ishah
Member level 1
Member level 1
Hi everyone,
I still got problems in my project, which I want to control LED with switch. But here nothing happen to PORTB.
Can anyone check my circuit in ISIS and my code.
    Project Title: Controled LED by switches
void main()
  TRISA=0XFF; //Configure all bit of PORTA as input
  TRISB=0X00; //Configure all bit of PORTB as output
  PORTA=0X00;       // Clear bits to zero
  PORTB=0X00;       // Clear bits to zero
  CMCON=0X07; //      or CMCON register = 0X00000111
  ADCON1=0X07; //     Configure ADCON1, or ADCON1=0X06;
while (1);
    if( TRISA.F0 == 1)   //If the switch is pressed
          Delay_ms(30);
          PORTB.F0 = ~PORTB.F0;   // Toggle LEDs on PORTB.0
          Delay_ms(500);         // Delay 1000 ms
    else
    if (TRISA.F1 == 1)   //If the switch is pressed
          Delay_ms(30);
          if( TRISA.F1 == 1)   //If the switch is pressed
          PORTB.F1 = ~PORTB.F1;   // Toggle LEDs on PORTB.1
    else
    if(TRISA.F2 == 1)   //If the switch is pressed
          Delay_ms(30);
          if( TRISA.F2 == 1)   //If the switch is pressed
          PORTB.F2 = ~PORTB.F2;   // Toggle LEDs on PORTB.2
          Delay_ms(1000);         // Delay 1000 ms
    else
    if(TRISA.F3 == 1)   //If the switch is pressed
          Delay_ms(30);
          if( TRISA.F3 == 1)   //If the switch is pressed
          PORTB.F3 = ~PORTB.F3;   // Toggle LEDs on PORTB.3
    else
    if(TRISA.F4 == 1)   //If the switch is pressed
          Delay_ms(30);
          if( TRISA.F4 == 1)   //If the switch is pressed
          PORTB.F4 = ~PORTB.F4;   // Toggle LEDs on PORTB.4
    else
    if(TRISA.F5 == 1)   //If the switch is pressed
          Delay_ms(30);
          if( TRISA.F5 == 1)   //If the switch is pressed
          PORTB.F5 = ~PORTB.F5;   // Toggle LEDs on PORTB.0
Thanks.
Use a flag like sw1.
unsigned sw1 = 0;
and replace if condition like this
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
if( TRISA.F0)   //If the switch is pressed
          Delay_ms(30);
               sw1 = 1;
if(sw1){
else{
        PORTB.F0 = 0;
unsigned sw1 = 0;
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
          Delay_ms(30);
               sw1 = 1;
if(sw1){
else{
        PORTB.F0 = 0;
I got error in my code. sorry im newbie in this field. Please guide me and give some example..
void main()
    ADCON1=0x07;
    CMCON=0;
    TRISB = 0x00;                                // set Port B pin as output
    TRISD = 0xff;                                // set Port D pin as input
    while(1)                                    // Endless loop
        if (PortD.F0==1)      // Detect logical one
           PortB.F0=1;     // switch on led
           while(PortD.F0);
        else if (PortD.F1==1)      // Detect logical one
           PortB.F1=1;
           while(PortD.F1);
        else if (PortD.F2==1)      // Detect logical one
           PortB.F2=1;
           while(PortD.F2);
        else if (PortD.F3==1)      // Detect logical one
           PortB.F3=1;
           while(PortD.F3);
        else if (PortD.F4==1)      // Detect logical one
           PortB.F4=1;
           while(PortD.F4);
        else if (PortD.F5==1)      // Detect logical one
           PortB.F5=1;
           while(PortD.F5);
        else
            PortB=0x00;
Check This program.. Hope this may Help You
Try this...
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
void main(){
     TRISA = 0xFF;
     PORTA = 0x00;
     TRISB = 0x00;
     PORTB = 0x00;
     unsigned char sw1 = 0;
     if( TRISA.F0){
          Delay_ms(30);
          if( TRISA.F0){   //If the switch is pressed
               sw1 = ~sw1;
     if(sw1){
     else{
          PORTB.F0 = 0;
Hi Aameer,
Thanks.
The code that you given is no error but I still didn't get a desired result. No LED will turn ON when i click the button.
Here is the result.
Try this...
Hi Jayanth,
Already try but still get error. Sorry Im quite slow to find out the error solution.
Use my code in post #5. It works but you have to add ADCON1 and CMCON settings to it before while(1) loop. You are using PORTA for switches and it has analog functions. To make it digital input pins Configure ADCON1 and CMCON registers. CMCON = 0x07 will do but for ADCON1 see the datasheet of PIC16F877A.
Edit:
Try this
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
void main(){
     TRISA = 0xFF;
     PORTA = 0x00;
     TRISB = 0x00;
     PORTB = 0x00;
     ADCON1 = 0b10000111;
     CMCON = 0x07;
     if( TRISA.F0){
          Delay_ms(30);
               sw1 = ~sw1;
     if(sw1){
     else{
          PORTB.F0 = 0;
void main()
while (1)
I already wrote the configuration for PIC16f877A as above.
But after i copy your code and run on my MicroC, i still have error (invalid expression, ; expected, but unsigned found etc)
What compiler are you using to build your code? Have you included the necessary files? that might be the problem.
@Ishah
i have connected Port D as input port and Port B as output... Try with that program
I am using the mikroC PRO for PIC from Mikroelektronika.
already configure the port A ADC , disable the comparator ...
Thanks
@Ishah
Thanks aameer, it works. After compare with yours, also work to my code at #1 so no need to change I/O, My mistake only at
while (1);
i should change to if( PORTA.F0 == 1).
Thanks everyone.
k..
TRIS is to mention whether it is input/output
Don't repeat the mistakes
All the Best
