ap2657
Newbie level 3
***********Error code is as follows:*************
** Warning: (vsim-3534) [FOFIR] - Failed to open file "switch.txt" for reading.
# No such file or directory. (errno = ENOENT) : C:/Modeltech_pe_edu_10.1d/examples/SystemVerilogPractice/associativeArray.sv(51)
# Time: 0 ps Iteration: 0 Instance: /associativeArry
# error in opening the file
****************Code excerpt is as follows:******
initial
begin : initial_block2
int i, r, file; // 32 bit values
string s;
// opening a file
file = $fopen ("switch.txt", "r");
if (file == 0)
begin
$display ("error in opening the file");
end
else
begin
$display ("success in opening the file");
end
end :initial_block2
****** Version details*************************
ModelSim PE student edition 10.1d
*** I have already tried the following things************************
1. Added the path Using: File>Source Directory
2. Added the path Using: Compiler options> Verilog & systemVerilog > Include Directroy
3. The file"Switch.txt" is in the work directory as well as in the project directory "SystemVerilogPractice"
initial
string s;
// opening a file
if (file == 0)
begin
end
else
begin
end
end :initial_block2
