I'm doing graphic lcd project. The lcd is 128x64 microcontroller is atmega32.
Please help how can do lcd setting and imagine picture and text in the 128x64 graphic lcd.
Please help me.
hello all.
My used graphic lcd has no any mark because this is china lcd.
The lcd has only pin mark. CS1, CS2, D/I, E, Reset, R/W, DB0-DB7 and power pins.
So this display might be same as other display with mark.
How can do instruction set of the display? how can iimagine picture and text any place of the display? Please help me?
To be sure you can look for the IC numbers in teh back of your LCD. You can have some memory ICs but you will find a microprocessor IC in your LCD module. Looking for the datasheet of that processor you will find the instructtions and so on.
Fortunatelly the are no many different kinds of processors. You will find the start up procedure, registers for operation and also the way of writing text and graphics
