please explain the below c program
rangerskm
Full Member level 4
Full Member level 4
this program not compiling in fedora.please correct the mistakes and explain the code.
#include <stdio.h>
   #include <stdlib.h>  /* for  atof() */
   #define MAXOP   100  /* max size of operand or operator */
   #define NUMBER  '0'  /* signal that a number was found */
   int getop(char []);
   void push(double);
   double pop(void);
   /* reverse Polish calculator */
   main()
       int type;
       double op2;
       char s[MAXOP];
       while ((type = getop(s)) != EOF) {
           switch (type) {
           case NUMBER:
               push(atof(s));
               break;
           case '+':
               push(pop() + pop());
               break;
           case '*':
               push(pop() * pop());
               break;
           case '-':
               op2 = pop();
               push(pop() - op2);
               break;
           case '/':
               op2 = pop();
               if (op2 != 0.0)
                   push(pop() / op2);
               else
                   printf("error: zero divisor\n");
               break;
           case '\n':
               printf("\t%.8g\n", pop());
               break;
           default:
               printf("error: unknown command %s\n", s);
               break;
       return 0;
What are the generated error messages when compilation is attempted?
Not the function prototypes listed above main:
   int getop(char []);
   void push(double);
   double pop(void);
The posting code is incomplete and is missing the implementation of the push(), pop() and getop() routines.
BigDog
code for push and pop function
#define MAXVAL  100  /* maximum depth of val stack */
   int sp = 0;          /* next free stack position */
   double val[MAXVAL];  /* value stack */
   /* push:  push f onto value stack */
   void push(double f)
       if (sp < MAXVAL)
           val[sp++] = f;
       else
           printf("error: stack full, can't push %g\n", f);
   /* pop:  pop and return top value from stack */
   double pop(void)
       if (sp > 0)
           return val[--sp];
       else {
           printf("error: stack empty\n");
           return 0.0;
code for getop function
#include <ctype.h>
   int getch(void);
   void ungetch(int);
   /* getop:  get next character or numeric operand */
   int getop(char s[])
       int i, c;
       while ((s[0] = c = getch()) == ' ' || c == '\t')
       s[1] = '\0';
       if (!isdigit(c) && c != '.')
           return c;      /* not a number */
       i = 0;
       if (isdigit(c))    /* collect integer part */
           while (isdigit(s[++i] = c = getch()))
       if (c == '.')      /* collect fraction part */
       s[i] = '\0';
       if (c != EOF)
           ungetch(c);
       return NUMBER;
they given the code as 3 seperate modules,i dont know to integrate it.
A typically example of compiling multiple source code files utilizing GCC:
gcc -Wall main.c second.c third.c -o progname
Simply replace main.c, second.c and third.c with the appropriate names of the source code files and choose a name for the resulting program in place of progname.
BigDog
