Jester
Full Member level 6
- Joined
- Aug 18, 2012
- Messages
- 377
- Helped
- 7
- Reputation
- 14
- Reaction score
- 7
- Trophy points
- 1,298
- Location
- Activity points
- 4,754
Are 2 cheap caps better than 1 good Cap with low ESR? Maybe but not if they have the same failure mode from high ESR.
Strategic Copper pour reduce EMI, balance copper layers and reduce thermal resistance is always good.
Did you evaluate the evaluation kit design layout & BOM?
The LM2576 data sheet example circuit has a 100 µF input capacitor, I think for a good reason.
The input current of a buck converter is pulsating by nature, if you operate it from a voltage source with some output impedance, you get respective input voltage ripple. The 10 µF in your circuit are probably sufficient to limit conducted noise in a pure digital system, but the 50 kHz AC current is mainly passed to the primary voltage source.
I used TI's online optimizer software and it reduced the input capacitor to the capacitors shown GRM31CR71H475KA12L
I wrongly assumed 50 kHz switching frequency but LM2596 is 150 kHz. The problem of input current ripple still exists. Obviously ceramic capacitors have no problem to stand the AC current, but it's stil bad design to send the ripple current back to the input source.
I wonder what are the "optimization" criteria of the TI tool.
