PLC to control - encoder_steper_motor
mgajo
Full Member level 2
Full Member level 2
plc with upto 250 khz pulse
Hi
What kind of PLC to use to control stepper motor with encoder?
Thanks
ash
Full Member level 3
Full Member level 3
Europe
ab hstp1 stepper
Hi Mgajo,
Please give some information about your stepper motor drive. Will you use microstepping?
mgajo
Full Member level 2
Full Member level 2
Hi , thanks
I am trying to use ISEL driver with direction and clock inputs
with 200/400 steps per revolution (no need for microstep),but must everything control with encoder too,so no missing movements at all.
thanks :?
servopump
Member level 2
Member level 2
Italia
Hi
Here is some info from Allen Bradley
see
https://www.ab.com/motion/controllers/stepper.html
The 1746-HSTP1 Stepper controller module is a single axis stepper controller. The 1746 stepper controller is a single slot module that is capable of operating with a wide variety of SLC 500 series processors. It can provide up to 250kHz pulse train output for micro-stepping applications.
The module works directly with compatible Allen-Bradley programmable controllers and encoders. Compatible SLC processors include the fixed units used with the 2-slot expansion rack, SLC 5/01, SLC 5/02, SLC 5/03 and SLC 5/04 modules. It is also compatible with larger PLC programmable controller systems via the 1747-ASB module interface.
enjoy :D
Servopump
mgajo
Full Member level 2
Full Member level 2
Ok
Thanks for link
bye :D
sklux
Member level 3
Member level 3
Schneider PLC Premium is also compatible with stepper motor, with the module TSXCFY** More infos on **broken link removed**.
You ll be able to find the reference manuals to see if it fit with your application
