l'm doing a design for a planar array for a smart antenna ... l'm using CST program for my design and l need to do a comparison for the function of the antenna when a 2*2, 4*4, 8*8 and 10*10 elements of the planar array are used ...
so, shall l use a coaxial port to feed each element or l should use the transmission line techniques to feed them all with a single normal port ...
actually, l'm looking for the way which is gana give me the better and compatible design for my application ...
thank you sir ... i just took a look in the decuments in the links and it seems to be so useful ... but should l just download the trail version .. or l can just get a cracked copy ....
