Sep 13, 2018 #1 P promach Advanced Member level 4 Joined Feb 22, 2016 Messages 1,199 Helped 2 Reputation 4 Reaction score 5 Trophy points 1,318 Activity points 11,636 wReady[0] = ~rValid[1] | wReady[1] wReady[0] = ~$past(_rValid[1]) | wReady[1] wReady[0] = ~$past(rValid[0] | (rValid[1] & ~wReady[1])) | wReady[1] wReady[0] = $past(~rValid[0] & (~rValid[1] | wReady[1])) | wReady[1] WR_DATA_READY = $past(~WR_DATA_VALID & (~RD_DATA_VALID | RD_DATA_READY)) | RD_DATA_READY Click to expand... For pipeline, do you guys have any comments about the above expression for WR_DATA_READY which is derived from line 40 and 59 of the following verilog code or reg_pipeline.v ? Code Verilog - [expand]1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 module reg_pipeline #( parameter C_DEPTH = 1, parameter C_WIDTH = 128 ) ( input CLK, input RST_IN, input [C_WIDTH-1:0] WR_DATA, input WR_DATA_VALID, output WR_DATA_READY, output [C_WIDTH-1:0] RD_DATA, output RD_DATA_VALID, input RD_DATA_READY ); genvar i; wire wReady [C_DEPTH:0]; reg [C_WIDTH-1:0] _rData [C_DEPTH:1], rData [C_DEPTH:0]; reg _rValid [C_DEPTH:1], rValid [C_DEPTH:0]; // Read interface assign wReady[C_DEPTH] = RD_DATA_READY; assign RD_DATA = rData[C_DEPTH]; assign RD_DATA_VALID = rValid[C_DEPTH]; // Write interface assign WR_DATA_READY = wReady[0]; always @(*) begin rData[0] = WR_DATA; rValid[0] = WR_DATA_VALID; end generate for( i = 1 ; i <= C_DEPTH; i = i + 1 ) begin : gen_stages assign #1 wReady[i-1] = ~rValid[i] | wReady[i]; // Data Registers always @(*) begin _rData[i] = rData[i-1]; end // Enable the data register when the corresponding stage is ready always @(posedge CLK) begin if(wReady[i-1]) begin rData[i] <= #1 _rData[i]; end end // Valid Registers always @(*) begin if(RST_IN) begin _rValid[i] = 1'b0; end else begin _rValid[i] = rValid[i-1] | (rValid[i] & ~wReady[i]); end end // Always enable the valid registers always @(posedge CLK) begin rValid[i] <= #1 _rValid[i]; end end endgenerate endmodule Last edited: Sep 13, 2018
Sep 13, 2018 #2 T TrickyDicky Advanced Member level 7 Joined Jun 7, 2010 Messages 7,110 Helped 2,081 Reputation 4,181 Reaction score 2,047 Trophy points 1,393 Activity points 39,769 In what context? I assume simulation or verification as $past is not synthesisable.
Sep 14, 2018 #3 P promach Advanced Member level 4 Joined Feb 22, 2016 Messages 1,199 Helped 2 Reputation 4 Reaction score 5 Trophy points 1,318 Activity points 11,636 input [C_WIDTH-1:0] WR_DATA, // Write data input input WR_VALID, // Write enable, high active output WR_READY, // ~Full condition output [C_WIDTH-1:0] RD_DATA, // Read data output input RD_READY, // Read enable, high active output RD_VALID // ~Empty condition Click to expand... I have understood it. Try to have a look at fifo.v or above input / output declaration and their code comments Code Verilog - [expand]1 WR_DATA_READY = $past(~WR_DATA_VALID & (~RD_DATA_VALID | RD_DATA_READY)) | RD_DATA_READY is similar to Code Verilog - [expand]1 WR_READY = $past(~WR_VALID & (~RD_VALID | RD_READY)) | RD_READY
Sep 14, 2018 #4 T TrickyDicky Advanced Member level 7 Joined Jun 7, 2010 Messages 7,110 Helped 2,081 Reputation 4,181 Reaction score 2,047 Trophy points 1,393 Activity points 39,769 But I don't understand what question you are asking? What are you trying to achieve
Sep 14, 2018 #5 D dave_59 Advanced Member level 3 Joined Dec 15, 2011 Messages 838 Helped 365 Reputation 734 Reaction score 360 Trophy points 1,353 Location Fremont, CA, USA Activity points 7,365 My comment is your expression makes no sense without more context. $past is mostly used in assertions.
