pejal
Hi, im doing freq reconfigurable antenna. So, im using PIN diode and lumped element.. How can i represent a PIn diode and lumped elements in cst?? Any additional setting or simulation setup??
Thankss
Thankss
The losses and isolation of PIN diodes have a significant effect on the simulation, so if you want accurate simulations you must include the diode model.
Including a circuital model in full-wave simulations is not straightforward. One effective way is to model the diode as a RLC boundary.
Actually, I've tried them (also for modelling PIN diodes) in HFSS and they work well. I don't know if it can be done in CST.
One tip: made the boundary as small as possible.
A different way consists on modelling the PIN diode is to locate a port instead and perform a post-processing loading the port with the circuit model.
Hi everybody, for PIN Diode simulation in CST you can applie two method:
1) you can simulate the PIN diode by its equivalent circuit (RLC)
2) Or you can simulate the PIN Diode like this: In the OFF mode, the PIN Diode is removed from the simulation and the antenna should be simulated with a complete slot. When the PIN is ON, it is modeled as a metal tape.
You can see this article, it will be very usefull for you:https://onlinelibrary.wiley.com/doi/10.1002/mop.27649/full
good luck and welcome for any question.
