Jan 24, 2017 #1 B B4M Member level 2 Joined Aug 3, 2016 Messages 47 Helped 1 Reputation 2 Reaction score 1 Trophy points 8 Activity points 318 Hi! I have decided to design a PIFA antenna as it gives an omni-directional pattern, and I wanted to know if I make a design with a short and a feed could it still be called a PIFA ?! Thank you
Jan 27, 2017 #2 anilkrpandey Member level 5 Joined Nov 4, 2016 Messages 81 Helped 19 Reputation 38 Reaction score 19 Trophy points 1,298 Location Gurgaon Activity points 2,269 The PIFA antenna radiator is mounted just above the ground layer and feed one arm of antenna w.r.t to ground. Can you put a picture of your design?
Jan 31, 2017 #3 B B4M Member level 2 Joined Aug 3, 2016 Messages 47 Helped 1 Reputation 2 Reaction score 1 Trophy points 8 Activity points 318 Dear anilkrpandey , please find attached the antenna design. Thank you!
Jan 31, 2017 #4 H hagster Member level 4 Joined Feb 18, 2015 Messages 70 Helped 14 Reputation 28 Reaction score 15 Trophy points 1,288 Activity points 1,746 Well its not strictly planar so strictly it should be called an IFA antenna, but if it works the name is not important.
