sresam89
Member level 2
dear all
the problem i am facing is that what ever i try to connect with my PB.6 PB.7 pins it is not working.
the program and all other part and files are good working flawlessly, even the same(PB.6 PB.7 pins) is working while using a different programmer.what would be the problem/solution for this?
i know these two two pins are used for programming the IC. i use 16f877a. this was tested using both ICSP and normal IC in socket programming.
thanks in advance
thanks in advance
