Shafaq Gul
Junior Member level 1
- Joined
- Dec 24, 2013
- Messages
- 18
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 122
Salam every one
I am using mplab C30 and am trying to send data serially but its not working.(p24FJ128GA006):-(...I have tried alot looking for help.
Waiting for reply sir...:!:
#include<p24FJ128GA006.h>
_CONFIG2(FNOSC_PRI & POSCMOD_HS )
_CONFIG1(FWDTEN_OFF & JTAGEN_OFF )
int main(void)
U1MODEbits.UARTEN=1;//uart enable
//U1MODEbits.STSEL=0;// One Stop bit
U1MODEbits.BRGH=1; //high baud rate
U1MODEbits.ABAUD=0;//Baud rate measurement disabled or completed
U1BRG=51;// as internal oscillator frequency 8Mhz
U1MODEbits.PDSEL0=0;//8-bit data, no parity
U1MODEbits.PDSEL1=0;
U1STAbits.UTXISEL0=0;//Interrupt when a character is transferred to the Transmit Shift Register (this implies there is at least one character open in the transmit buffer)
U1STAbits.UTXISEL1=1;
U1MODEbits.UEN0=0;// UxTX and UxRX pins are enabled and used; UxCTS and UxRTS/BCLKx pins controlled by PORT latches
U1MODEbits.UEN1=0;
TRISF=0;
TRISD=0xFF;
LATD=0;
LATF=0;
//U1MODE = 0x8000;
//U1STA = 0x8400;
carriage_return();
while(1); //end
return 0;
//aes256_done(&ctx);
void carriage_return(void)
U1STAbits.UTXEN=1;
U1TXREG=0x0D;
while(U1STAbits.UTXBF == 1);//wait until all transmitted.
U1STAbits.UTXBF = 1;
