ponnus
Full Member level 2
- Joined
- Mar 17, 2011
- Messages
- 142
- Helped
- 8
- Reputation
- 16
- Reaction score
- 8
- Trophy points
- 1,298
- Location
- Cochin, INDIA
- Activity points
- 2,226
Hai,
I am trying to use RA4 pin of PIC24F16KA101 as digital output.It is connected to one of the segments of the 7-segment display. But it is always giving a constant voltage of about 800mv. I am not able to drive this pin.
I checked the datasheet to know if it is an open drain, but that is not mentioned in the datasheet. I also tried setting it as open drain (ODCAbits.ODA4 = 1), and used a pull up resistor of 10K to Vcc(Vcc=3V). But still unable to drive it.
Does anyone faced such a problem?Any help is appreciated.....
Thank you
Thank you
