void Timer1init()
T1CON = 0x00; //Stops the Timer1 and reset control reg.
TMR1 = 0x00; //Clear contents of the timer register
PR1 = 4000; //Load the Period register with 1mSec counter
// PR1 = 16000U; //Load the Period register with 1mSec counter
IPC0bits.T1IP = 0x01; //Setup Timer1 interrupt for desired priority level
// (This example assigns level 1 priority)
IFS0bits.T1IF = 0; //Clear the Timer1 interrupt status flag
IEC0bits.T1IE = 1; //Enable Timer1 interrupts
T1CONbits.TON = 1; //Start Timer1 with prescaler settings at 1:1 and
//clock source set to the internal instruction cycle
volatile int mSecDelayCounter=0; // used in the millsecond delay function
/* interrupt service routine for Timer1 ISR*/
void __attribute__((__interrupt__, __shadow__)) _T1Interrupt(void)
/* Interrupt Service Routine code goes here */
IFS0bits.T1IF = 0; //Reset Timer1 interrupt flag
mSecDelayCounter--;
