[PIC] PIC18Fx5K22..Cannot get a a single pin PWM CCP1 RC2 to work
Hoffman
Newbie level 3
Despite reading the spec sheet (and especially section 14.13.2) and although carefully following the steps, I cannot seem to get CCP1 pin RC2 to output a PWM signal.
All though there are many possible complex PWM bridge output configurations, I would really like to know how many single-output simple PWM's are possible.
My code attempt to get CCP1 RC2 TMR4 to work:
I can see with the initialization below that TMR4 is counting and overlowing, but RC2 pin stays always at Vss.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
void PWM1Setup(void)// CCP1 cbit2 using TMR4
TRISC2=0; //PWM  requires the PWM pin TRIS'd as output
//Select 8-bit Timer TMR4: Choices for CCP1 are TMR2/TMR4/TMR6,using  CxTSEL<1:0> bits of CCPTMRS0
//C1TSEL=0x01; //TMR4 selected   options are: 10=TMR6 00=TMR2 01=TMR4
CCPTMRS0=(CCPTMRS0 & 0xFC); //Mask to leave C3TSEL and C2TSEL unchanged
CCPTMRS0=(CCPTMRS0 | 0x01); //C1TSEL=0x01 TMR4 selected
/* T4CON
   Bit  7      6      5     4      3     2      1   0
        x      0      0     0      1     1      0   0
               TxOUTPS<3:0>
               POSTSCALER 1:2 to 1:16  TMxOn    PRESCALER
                                                1:1=00 01=1:4 1x1:/16
T4CON=0b00001100;
//CCP1CON holds duty cycle LSb in bits<5:4>LSbs, but CCPR1L=MSbits
CCP1CON=0;//(CCP1CON & 0xCF); //Mask P1M bits, MSbits of DCyc=0, CPR1H not used
PR4=0xFF; //overflow count 0XFF for 10-bit resolution for any PWM freq.
CCP1IE=0; // Disable CCP1 IRQ enable not used for PWM only mode
          //For 10-bit resolution, Switching P/S inductor must be >900uH/18v
          //19.53KHz period approx 50uSec                         >600UH/12v
TMR4IE = 0;    // enable TIMER4 interrupt
PEIE   = 1;    // enable peripheral interrupts
TMR4ON = 1;    //Turn on TMR4  used for duty cycle period
//setting duty cycle: DCyc is set in the low-priority isr that is working ok, periodically triggered at 100uSec using TMR0:
//--------------------SET PWM Duty Cycle-------------------------------
    CCP1CONbits.DC1B0 = DCyc & 1; //set low bit
    CCP1CONbits.DC1B1 = (DCyc >> 1) & 1;  //set second lowest
    CCPR1L = (DCyc >> 2); //sets DCycH hi 8 hi-bits
    TMR4IF=0;
//main() initialization:
void main(void)
  Init_PIC();
  Init_TMR0();
  PWM1Setup();//Setup CCP1 cbit2 PWM
  IPEN  =1;   //Priority interrupts enabled
  TMR0IE=1;
  TMR0ON=1;
  TMR0IP=0;
  TMR4IP=0;
  TMR4ON=1;
  TMR4IP=0;
  TMR4IE=0;
  CCP1IE=0;   //these settings may not be necessary
  CCP1IP=0;
//  PIE1=1;   //Not Needed for TMRx
//  PIE2=1;   //Not Needed for TMRx
    PLLEN =1;
    PEIE  =1;   //Needed for TMRx interrupts
    GIEL=1;   //Enables Low-Priority if GIEH/GIE=1
    GIEH=1;   //Ok to use INTCONbits.GIE = 1; to enable all interrupts
 //======================== START =======================================
  Start:
  DCyc=500;
 goto Start;
 //I have set RC6 pin to toggle on/off, verified TMR0 IRQ's are fine, TMR4 counter is running and overflowing.
//but RC2 stays at Vss
