Valdez85
Junior Member level 1
Hey guys,
I have this code and it works fine, but i added the serial interrupt and the project stop works. I dont know what im doing wrong. Can you guys help me pls?
My pic is in sleep mode at start and wake up, take some measures and go to sleep mode again.
And now i want the same but if i press a button from keyboard the pic take the measures until i press the button again.
#include <stdio.h>
#include <stdlib.h>
#include <xc.h>
#include <usart.h>
#include <adc.h>
#include <delays.h>
#include <i2c.h>
#pragma config FOSC = HSMP
#pragma config PWRTEN = ON
#pragma config MCLRE = EXTMCLR
#pragma config HFOFST = ON
#pragma config WDTEN = SWON
#pragma config WDTPS = 2048
#define _XTAL_FREQ 8000000
#define I2C_FREQ 100000
#define uch unsigned char //
#define DQ PORTCbits.RC0 //define 18B20 data PORT
#define DQ_DIR TRISC0 //define 18B20 D PORT direct register
#define DQ_HIGH() DQ_DIR =1 //set data PORT INPUT
#define DQ_LOW() DQ = 0; DQ_DIR = 0 //set data PORT OUTPUT
unsigned char TLV = 0; //temperature high byte
unsigned char THV = 0; //temperature low byte
unsigned char TZ = 0; //temperature integer after convert
unsigned char TX20 = 0; //temperature decimal after convert
unsigned int wd; //temperature BCD code after convert
unsigned char tram;
unsigned char chuc;
unsigned char donvi;
unsigned char le;
unsigned char sec, min, hr, week_day, day, mn, year;
unsigned char stringfinal[32];
unsigned char tmp[5];
unsigned int ph;
unsigned int amo;
unsigned int clo;
unsigned char I2CData[] = {"123456"};
unsigned char dataout[30];
void readDS1307(char *sec, char *min, char *hr, char *week_day, char *day, char *mn, char *year) {
StartI2C2();
WriteI2C2(0xD0);
WriteI2C2(0x00);
RestartI2C2();
WriteI2C2(0xD1);
*sec = ReadI2C2();AckI2C2();
*min = ReadI2C2();AckI2C2();
*hr = ReadI2C2();AckI2C2();
*week_day = ReadI2C2();AckI2C2();
*day = ReadI2C2();AckI2C2();
*mn = ReadI2C2();AckI2C2();
*year = ReadI2C2();
NotAckI2C2();
StopI2C2();
void writeDS1307() {
StartI2C2();
WriteI2C2(0xD0);
WriteI2C2(0x00);
WriteI2C2(0x00); // sec
WriteI2C2(0x00); //minutes
WriteI2C2(0x00); // hours
WriteI2C2(0x00); //week_day
WriteI2C2(0x01); //date
WriteI2C2(0x01); //month
WriteI2C2(0x15); //year
WriteI2C2(0x10); // REG 7 - Enable squarewave output pin1hz
StopI2C2();
void Transform_Time(char *sec, char *min, char *hr, char *week_day, char *day, char *mn, char *year) {
*sec = ((*sec & 0x70) >> 4)*10 + (*sec & 0x0F);
*min = ((*min & 0x70) >> 4)*10 + (*min & 0x0F);
*hr = ((*hr & 0x30) >> 4)*10 + (*hr & 0x0F);
*week_day = (*week_day & 0x07);
*day = ((*day & 0x30) >> 4)*10 + (*day & 0x0F);
*mn = ((*mn & 0x70) >> 4)*10 + (*mn & 0x0F);
*year = ((*year & 0xF0) >> 4)*10 + (*year & 0x0F);
void delay(int uSeconds) {
int s;
for (s = 0; s < uSeconds; s++);
void reset(void) {
char presence = 1;
while (presence) {
DQ_LOW(); //MAIN MCU PULL LOW
delay(41); //delay 503us
DQ_HIGH(); //release general line and wait for resistance pull high general line and keep 15~60us
delay(5); //delay 70us
if (DQ == 1) presence = 1; // not receive responsion signal,continue reset
else presence = 0; //receive responsion signal
delay(40); //delay 430us
void write_byte(uch val) {
uch i;
uch temp;
for (i = 8; i > 0; i--) {
temp = val & 0x01; //shift the lowest bit
DQ_LOW();
NOP();NOP();NOP();NOP();NOP(); //pull high to low,produce write time
if (temp == 1) DQ_HIGH(); //if write 1,pull high
delay(5); //delay 63us
DQ_HIGH();
NOP();NOP();
val = val >> 1; //right shift a bit
uch read_byte(void) {
uch i;
uch value = 0; //read temperature
static bit j;
value >>= 1;
DQ_LOW();
NOP();NOP();NOP();NOP();NOP();NOP(); //6us
DQ_HIGH(); // pull high
NOP();NOP();NOP();NOP();NOP(); //4us
j = DQ;
if (j) value |= 0x80;
delay(5); //63us
return (value);
void get_temp() {
int i;
DQ_HIGH();
reset(); //reset,wait for 18b20 responsion
write_byte(0XCC); //ignore ROM matching
write_byte(0X44); //send temperature convert command
for (i = 20; i > 0; i--) {
NOP();
reset(); //reset again,wait for 18b20 responsion
write_byte(0XBE); //send read temperature command
TLV = read_byte(); //read temperature low byte
THV = read_byte(); //read temperature high byte
TZ = ((TLV >> 4) | (THV << 4)); // & 0X3f; //temperature integer
TX20 = TLV << 4; //temperature decimal
donvi = TZ % 10; //integer Entries bit
chuc = (TZ % 100) / 10; //integer ten bit
tram = TZ / 100;
wd = 0;
if (TX20 & 0x80) wd = wd + 5000;
if (TX20 & 0x40) wd = wd + 2500;
if (TX20 & 0x20) wd = wd + 1250;
if (TX20 & 0x10) wd = wd + 625; //hereinbefore four instructions are turn decimal into BCD code
le = wd / 1000; //ten cent bit
NOP();
sprintf(tmp, "%d.%d", TZ, le);
void initDS1307(void) {
OpenI2C2(MASTER, SLEW_OFF);
Delay10KTCYx(25);
SSP2ADD = (_XTAL_FREQ / (4 * I2C_FREQ)) - 1;
StartI2C2();
IdleI2C2();
Delay10KTCYx(25);
writeDS1307();
void analogicSensors(void) {
SelChanConvADC(ADC_CH0);
while (BusyADC()); //infinite loop
ph = ReadADC(); //ReadADC();
SelChanConvADC(ADC_CH1);
amo = ReadADC();
SelChanConvADC(ADC_CH2);
clo = ReadADC();
void init24C64() {
OpenI2C1(MASTER, SLEW_OFF);
Delay10KTCYx(25);
SSP1ADD = (_XTAL_FREQ / (4 * I2C_FREQ)) - 1; //set i2c clock
Delay10KTCYx(25);
void write24C64(){
StartI2C1();
WriteI2C1(0xA0);
WriteI2C1(0x00);
WriteI2C1(0x00);
for(int j=0;j<6;j++){
WriteI2C1(I2CData[j]);
WriteI2C1(0x10);
StopI2C1();
void read24C64(){
StartI2C1();
WriteI2C1(0xA0);
WriteI2C1(0x00);
WriteI2C1(0x00);
RestartI2C1();
WriteI2C1(0xA1);
//for(int j=0;j<6;j++){
//dataout[j] = ReadI2C1();
// puts1USART(itoa(stringfinal, dataout, 10));
dataout[0] = ReadI2C1();
AckI2C1();
dataout[1] = ReadI2C1();
AckI2C1();
dataout[2] = ReadI2C1();
AckI2C1();
dataout[3] = ReadI2C1();
AckI2C1();
dataout[4] = ReadI2C1();
AckI2C1();
dataout[5] = ReadI2C1();
puts1USART(dataout);
NotAckI2C1();
StopI2C1();
void interrupt RxInterrupt()
unsigned char data;
if(PIR1bits.RC1IF == 1)
data = Read1USART(); //read the byte from rx register
if (DataRdy1USART() == 1)
if (data == 's') {
LATDbits.LD2 = 1;
puts1USART("\nReal Time Data ON");
readDS1307(&sec, &min, &hr, &week_day, &day, &mn, &year);
Transform_Time(&sec, &min, &hr, &week_day, &day, &mn, &year);
get_temp();
analogicSensors();
sprintf(stringfinal, "\n%02d/%02d/%02d,%02d:%02d:%02d,%s,%d,%d,%d", day, mn, year, hr, min, sec, tmp, ph, amo, clo);
puts1USART(stringfinal);
//Write1USART(data);
PIR1bits.RC1IF = 0; // clear rx flag
void globalReset(void) {
//ANSELA = 0x00;
//ANSELB = 0x00;
ANSELC = 0x00;
ANSELD = 0x00;
//ANSELE = 0x00;
void main(void) {
globalReset();
initDS1307();
init24C64();
//INTCONbits.GIE = 1; // enable global interrupts
//INTCONbits.PEIE = 1; // enable peripheral interrupts.
//PIE1bits.RC1IE = 1; // enable USART rx interrupt
TRISA = 0b00000111;
TRISDbits.TRISD2 = 0;
LATDbits.LD2 = 0;
CLRWDT();
WDTCONbits.SWDTEN = 1;
// ei();
while (1) {
for (int xpto = 0; xpto < 2; xpto++) {
Close1USART();
CloseADC();
LATDbits.LD2 = 0;
SLEEP();
Open1USART(USART_TX_INT_OFF & USART_RX_INT_ON & USART_ASYNCH_MODE & USART_EIGHT_BIT & USART_BRGH_HIGH, 51);
OpenADC(ADC_FOSC_64 & ADC_RIGHT_JUST & ADC_20_TAD, ADC_CH0 & ADC_INT_ON, ADC_TRIG_CTMU & ADC_REF_VDD_VDD & ADC_REF_VDD_VSS);
LATDbits.LD2 = 1;
SLEEP();
get_temp();
Delay10KTCYx(200);
LATDbits.LD2 = 1;
get_temp();
analogicSensors();
write24C64();
Delay10KTCYx(200);
read24C64();
