Murugesh_89
Full Member level 5
- Joined
- Nov 23, 2012
- Messages
- 266
- Helped
- 7
- Reputation
- 12
- Reaction score
- 6
- Trophy points
- 1,298
- Location
- India
- Activity points
- 3,267
I am using the pic 18f45k22 microcontroller using 5V supply and the MCLR circuit i have given as
After i powered up my device voltage at mclr with respect to Vss is measured as 1.5V.
I thought the resistance R1 is less so i changed to 22K. Then also i got 1.5V at MCLR.
Then i suspect the pic ic then i changed another new pic ic. This too leads the same 1.5V at MCLR.
I think due to this lower voltage the controller does not running the code in it.
Can somebody give me a solution for this?
Thanks,
Murugesh
Thanks,
Murugesh
