Pic18f4550 uart problem
pratheeshprm143
Newbie level 6
india
Hai
I am using PIC18F4550 with USB (20MHz xtal). When i try to send data through UART, my serial port does not get the actual data that I have send.
When I try to send data 00-FF, only some values are correct (7,8,9, j,k,l,m & n). I think the problem is in my baud rate. I have tried more than twenty configurations from many blogs. But the problem is not fixed. I am using C18 toolkit. My code well worked with proteus simulator. Also the port (PORTB) bits are changed in my hardware. Here is my code and configuration bit settings.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
#include <p18f4550.h>
unsigned int i,j;
void delay(int);
void main(void)
    TRISB=0x00;
    PORTB=0X00;
    TXSTA=0x20;
    SPBRG=0x20;
    TXSTAbits.TXEN=1;
    RCSTAbits.SPEN=1;
while(1)
    TXREG='G';
    while(PIR1bits.TXIF==0);
    delay(100);
    PORTB=~PORTB;
void delay(int d)
    for(i=0;i<d;i++)
        for(j=0;j<d;j++)
I have also tried many SPBRG values for 20MHZ crystal like 1Eh,1Fh,20H,21H and so on(with the equation in data sheet).
//MCC18 PIC18F4550
    TXSTAbits.TX9=0;
    TXSTAbits.TX9D=0;
    TXSTAbits.SYNC=0;
    TXSTAbits.TXEN=1;
    TXSTAbits.BRGH=1;
    RCSTAbits.CREN=1;
    BAUDCONbits.BRG16=0;SPBRGH=0; SPBRG=129;          // 9600KBaud   20Mhz clock
    RCSTAbits.SPEN=1;
