pic18f4520 and nokia3310 LCD
senatorsegun
Newbie level 3
nigeria
please, i need help on displaying characters on nokia3310 lcd screen. The best i could have were 2 or 3 layers of lines drawn at the bottom of the screen. I interfaced it with pic18f4520 and i am using 8MHz oscillator to drive the PIC. Could that be a problem because most projects use 20MHz.
My codes and circuit design runs on proteus but the hardware is not coming on. Please what could be the problem?:idea:
Hello!
Having written a few LCD drivers, I would say that if you already have
something on the screen, it means that you did 90% of the work.
Now what might be surprising at first: this LCD is a black & white device. So
when you write 1 byte, it displays 8 pixels vertically. For instance, if you write
0xFF, then you will have a 8 black pixels vertical segment. If you write 0xF0,
you will have 4 black and 4 non-black pixels, etc.
So, supposing you want to write "0", you have to create a bitmap first.
"0" in a 8x5 char scheme can be written like this:
{0x3E, 0x51, 0x49, 0x45, 0x3E}.
If you translate this to * and spaces, you obtain:
So if you write this 5-byte data sequence, you will get a "0" at the screen.
Now some hints: somewhere in the initialization process, there should be
some instruction to define the position in the internal DRAM.
So you should write a function like this:
void MoveTo(uint8 line, uint8 col) {
[write cursor move instructions here]
line is between 0 and 5 (you have 48 lines of pixels) and col is between
0 and 83.
Then if you MoveTo(0,0), you will be at the topleft of the screen.
There are a few hints .
Dora.
Here is my code:
#include <18F4520.h>
#device adc=8
#include <nokia3310Driver.c>
#FUSES NOWDT //No Watch Dog Timer
#FUSES HS //Low power osc < 200 khz
/*#FUSES NOPROTECT //Code not protected from reading
#FUSES BROWNOUT //Reset when brownout detected
#FUSES BORV25 //Brownout reset at 2.5V
#FUSES PUT //Power Up Timer
#FUSES NOCPD //No EE protection
#FUSES STVREN //Stack full/underflow will cause reset
#FUSES NODEBUG //No Debug mode for ICD*/
#FUSES NOLVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#use delay(clock=8000000)
//#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
//#use delay(clock=8000000)
void main()
//Setup_Oscillator parameter not selected from Intr Oscillotar Config tab
// TODO: USER CODE!!
int i=0;
//REmember, you must define and initialise all variables here!!!
char fName[10]="Ade", lName[10]="Olusegun";
//you must call initlcd before doing anything else with lcd
initlcd();
while(true)
clearram();
//delay_ms(500);
delay_ms(50);
//cursorxy(1,0);
cursorxy(i,0);
//putstr(fName);
putstr(fName);
cursorxy(30,0);
putstr(lName);
cursorxy(1,1);
putstr(fName);
cursorxy(30,1);
putstr(lName);
cursorxy(1,5);
putstr(fName);
cursorxy(30,5);
putstr(lName);
delay_ms(500);
i++;
//now you can call any function from the driver to modify brightness, determine where to write next, write a character, or a string.
Nokia 3310 LCD Demo. Codes are partially modified from Michel
Bavin's CCS C Codes for Nokia 3310 Graphical LCD
(LPH7779) routines version 3 from **broken link removed**
Connection:
- get the pinout of the 3310 screen online
- how the 3310 pins are connected to the PIC pin are defined by the define statements below:
#define SCK PIN_D7 // Connections between PIC and LCD.
#define SDI PIN_D6
#define D_C PIN_D5
#define _SCE PIN_D4
#define _RES PIN_D3
The above shows that by default, pins D3 to D7 are used by this code.
You can change by modifying the #define statements below.
The 480-byte large array "Table" is used to define the font used for the display.
The comment on each line of the code for declaring the array shows the character that line defines.
DO NOT MESS WITH THIS TABLE AT ALL UNLESS YOU NEED TO CHANGE THE STYLE WITH WHICH A PARTICULAR CHARACTER IS DISPLAYED
Contrastup and contrastdown increase or reduce the contrast by a small amount respectively each time they are called
Initlcd must be called before any other thing is done with or to the lcd. It needs to be called only once close to the beginning of your code.
There is no need to call it again unless program execution resets for whatever reason
Writecomm, Writedata,Clockdata : DO NOT these functions. They are called by some other functions.
Clearam clears the entire screen
Cursorxy places the cursor at a screen location. Note that the cursor itself is invisible. Use Cursor XY to
determine where the next character you write will appear.
Putlcdchar allows you to write a single character to the LCD at the present cursor location. Character written with a foreground of
black and a background of white.
Putlcdcharinv writes a single character to the LCD. Difference is that the character is written with a foreground of white on a background of black.
putstr and putstrinv both write an array of chacters to the LCD. outstr writes with a forground of black on white while putstrinv
writes with white on a black background.
// Structures used by LCD
#define SDI PIN_D6
#define D_C PIN_D5
#define _SCE PIN_D4
#define _RES PIN_D3
int lcdcontrast = 216; //Contrast initially set at 216
void initlcd(void); // Initializes the LCD.
void writecom(char); // Writes a command.
void writedata(char); // Writes data to DDRAM to illuminate the pixels.
void clockdata(char); // Clocks in data into the PCD8544 controller.
void clearram(void); // Erase the DDRAM contents.
void cursorxy(char,char); // Position cursor to x,y.
void putlcdchar(char); // Write one character.
void putlcdcharinv(char); // Write one character.
void putstr(char *message); // Writes a string of characters.
void putstrinv(char *message); // Writes a string of characters.
const char table[480] = { 0x00,0x00,0x00,0x00,0x00,// 20 space ASCII table for NOKIA LCD: 96 rows * 5 bytes= 480 bytes
0x00,0x00,0x5f,0x00,0x00, // 21 ! Note that this is the same set of codes for character you
0x00,0x07,0x00,0x07,0x00, // 22 " would find on a HD44780 based character LCD. :)
0x14,0x7f,0x14,0x7f,0x14, // 23 # Also, given the size of the LCD (84 pixels by 48 pixels),
0x24,0x2a,0x7f,0x2a,0x12, // 24 $ the maximum number of characters per row is only 14. :)
0x23,0x13,0x08,0x64,0x62, // 25 %
0x36,0x49,0x55,0x22,0x50, // 26 &
0x00,0x05,0x03,0x00,0x00, // 27 ' KAY: 480 bytes above obtained only from fact that the table has 96 elements
0x00,0x1c,0x22,0x41,0x00, // 28 ( and not from any physical limitation of the LCD itself
0x00,0x41,0x22,0x1c,0x00, // 29 )
0x14,0x08,0x3e,0x08,0x14, // 2a *
0x08,0x08,0x3e,0x08,0x08, // 2b +
0x00,0x50,0x30,0x00,0x00, // 2c ,
0x08,0x08,0x08,0x08,0x08, // 2d -
0x00,0x70,0x70,0x70,0x00, // 2e . // changed from 0x00,0x60,0x60,0x00,0x00 on 27/02/09
0x20,0x10,0x08,0x04,0x02, // 2f /
0x3e,0x51,0x49,0x45,0x3e, // 30 0 //start
0x00,0x42,0x7f,0x40,0x00, // 31 1
0x42,0x61,0x51,0x49,0x46, // 32 2
0x21,0x41,0x45,0x4b,0x31, // 33 3
0x18,0x14,0x12,0x7f,0x10, // 34 4
0x27,0x45,0x45,0x45,0x39, // 35 5
0x3c,0x4a,0x49,0x49,0x30, // 36 6
0x01,0x71,0x09,0x05,0x03, // 37 7
0x36,0x49,0x49,0x49,0x36, // 38 8
0x06,0x49,0x49,0x29,0x1e, // 39 9
0x00,0x36,0x36,0x00,0x00, // 3a :
0x00,0x56,0x36,0x00,0x00, // 3b ;
0x08,0x14,0x22,0x41,0x00, // 3c <
0x14,0x14,0x14,0x14,0x14, // 3d =
0x00,0x41,0x22,0x14,0x08, // 3e >
0x02,0x01,0x51,0x09,0x06, // 3f ?
0x32,0x49,0x79,0x41,0x3e, // 40 @
0x7e,0x11,0x11,0x11,0x7e, // 41 A
0x7f,0x49,0x49,0x49,0x36, // 42 B
0x3e,0x41,0x41,0x41,0x22, // 43 C
0x7f,0x41,0x41,0x22,0x1c, // 44 D
0x7f,0x49,0x49,0x49,0x41, // 45 E
0x7f,0x09,0x09,0x09,0x01, // 46 F
0x3e,0x41,0x49,0x49,0x7a, // 47 G
0x7f,0x08,0x08,0x08,0x7f, // 48 H
0x00,0x41,0x7f,0x41,0x00, // 49 I
0x20,0x40,0x41,0x3f,0x01, // 4a J
0x7f,0x08,0x14,0x22,0x41, // 4b K
0x7f,0x40,0x40,0x40,0x40, // 4c L
0x7f,0x02,0x0c,0x02,0x7f, // 4d M
0x7f,0x04,0x08,0x10,0x7f, // 4e N
0x3e,0x41,0x41,0x41,0x3e, // 4f O
0x7f,0x09,0x09,0x09,0x06, // 50 P
0x3e,0x41,0x51,0x21,0x5e, // 51 Q
0x7f,0x09,0x19,0x29,0x46, // 52 R
0x46,0x49,0x49,0x49,0x31, // 53 S
0x01,0x01,0x7f,0x01,0x01, // 54 T
0x3f,0x40,0x40,0x40,0x3f, // 55 U
0x1f,0x20,0x40,0x20,0x1f, // 56 V
0x3f,0x40,0x38,0x40,0x3f, // 57 W
0x63,0x14,0x08,0x14,0x63, // 58 X
0x07,0x08,0x70,0x08,0x07, // 59 Y
0x61,0x51,0x49,0x45,0x43, // 5a Z
0x00,0x7f,0x41,0x41,0x00, // 5b [
0x02,0x04,0x08,0x10,0x20, // 5c Yen Currency Sign
0x00,0x41,0x41,0x7f,0x00, // 5d ]
0x04,0x02,0x01,0x02,0x04, // 5e ^
0x40,0x40,0x40,0x40,0x40, // 5f _
0x00,0x01,0x02,0x04,0x00, // 60 `
0x20,0x54,0x54,0x54,0x78, // 61 a
0x7f,0x48,0x44,0x44,0x38, // 62 b
0x38,0x44,0x44,0x44,0x20, // 63 c
0x38,0x44,0x44,0x48,0x7f, // 64 d
0x38,0x54,0x54,0x54,0x18, // 65 e
0x08,0x7e,0x09,0x01,0x02, // 66 f
0x0c,0x52,0x52,0x52,0x3e, // 67 g
0x7f,0x08,0x04,0x04,0x78, // 68 h
0x00,0x44,0x7d,0x40,0x00, // 69 i
0x20,0x40,0x44,0x3d,0x00, // 6a j
0x7f,0x10,0x28,0x44,0x00, // 6b k
0x00,0x41,0x7f,0x40,0x00, // 6c l
0x7c,0x04,0x18,0x04,0x78, // 6d m
0x7c,0x08,0x04,0x04,0x78, // 6e n
0x38,0x44,0x44,0x44,0x38, // 6f o
0x7c,0x14,0x14,0x14,0x08, // 70 p
0x08,0x14,0x14,0x18,0x7c, // 71 q
0x7c,0x08,0x04,0x04,0x08, // 72 r
0x48,0x54,0x54,0x54,0x20, // 73 s
0x04,0x3f,0x44,0x40,0x20, // 74 t
0x3c,0x40,0x40,0x20,0x7c, // 75 u
0x1c,0x20,0x40,0x20,0x1c, // 76 v
0x3c,0x40,0x30,0x40,0x3c, // 77 w
0x44,0x28,0x10,0x28,0x44, // 78 x
0x0c,0x50,0x50,0x50,0x3c, // 79 y
0x44,0x64,0x54,0x4c,0x44, // 7a z
0x00,0x08,0x36,0x41,0x00, // 7b <
0x00,0x00,0x7f,0x00,0x00, // 7c |
0x00,0x41,0x36,0x08,0x00, // 7d >
0x10,0x08,0x08,0x10,0x08, // 7e Right Arrow ->
0x78,0x46,0x41,0x46,0x78}; // 7f Left Arrow <-
void contrastup(void)
//write 000100 001
//000100 in ANY mode sets the mode (value of H and V etc)
if(lcdcontrast<250)
writecom(0x21); // Activate Chip and H=1. bit PD=0, V=0, H=1 //
lcdcontrast=lcdcontrast+5;
writecom(lcdcontrast); // Set LCD Voltage to about 7V. //Kay changed from C2
writecom(0x20); // Horizontal addressing and H=0.
void contrastdown(void)
if(lcdcontrast>132)
lcdcontrast=lcdcontrast-5;
void initlcd(void)
output_high(_RES); // Set _RES HIGH.
output_high(_SCE); // Disable Chip.
output_low(_RES); // Reset the LCD.
//delay_ms(100); // Wait 100ms.
output_high(_RES); // Awake LCD from RESET state.
writecom(0x13); // Adjust voltage bias.
writecom(0x20); // Horizontal addressing and H=0. //Can change to vertical mode to draw screen, but hope no stress associated
//H doesn't need to be set to 1 any more unless we need to change Bias or LCD Voltage
//to set to vertical address mode, writecom(0x22)
writecom(0x09); // Activate all segments.
clearram(); // Erase all pixel on the DDRAM.
writecom(0x08); // Blank the Display.
writecom(0x0C); // Display Normal.
cursorxy(0,0); // Cursor Home.
void writecom(char command_in)
output_low(D_C); // Select Command register.
output_low(_SCE); // Select Chip.
clockdata(command_in); // Clock in command bits.
output_high(_SCE); // Deselect Chip.
void writedata(char data_in)
output_high(D_C); // Select Data register.
clockdata(data_in); // Clock in data bits.
void clockdata(char bits_in)
int bitcnt;
for (bitcnt=8; bitcnt>0; bitcnt--)
output_low(SCK);
// Set Clock Idle level LOW.
if ((bits_in&0x80)==0x80) {output_high(SDI);} // PCD8544 clocks in the MSb first.
else {output_low(SDI);}
output_high(SCK); // Data is clocked on the rising edge of SCK.
//ADDED BY KAY
bits_in=bits_in<<1; // Logical shift data by 1 bit left.
// CLEARRAM: clears the RAM by writing blanks to every single RAM location
// Each RAM location controls 8 vertical pixels
void clearram(void)
int16 ddram;
for (ddram=700;ddram>0;ddram--) {writedata(0x00);} // 6*84 = 504 DDRAM addresses. //changed to 600 to troubleshoot
// CURSORXY: Uses appropriate Command to take "cursor" to right RAM address.
// This is probably done by specifying a RAM address to go to
void cursorxy(char x, char y)
writecom(0x40|(y&0x07)); // Y axis
writecom(0x80|(x&0x7f)); // X axis
void putlcdchar(char character)
int16 tablept;
int16 characterint;
int count;
int char_column;
if ((character<0x20)||(character>0x7f)) {return;}// Exit function if character is not found.
characterint=character;
tablept = ((5*characterint) - 160); // Point to the columns of the character in the table.
for (count=5;count>0;count--) // Draw the columns to print the character.
char_column = table[tablept];
writedata(char_column);
tablept++;
writedata(0x00); // 1 pixel spacing per character.
void putlcdcharinv(char character)
int16 tablept;
int16 characterint;
int count;
int char_column;
char_column = table[tablept]^0xFF;
tablept++;
writedata(0xFF); // 1 pixel spacing per character.
// int i=0;
while(*message) {putlcdchar(*message++);} // Points to one ASCII to be written one at a time.
// while((i<30)&&(message))
// putchar(message);
// i++;
while(*message) {putlcdcharinv(*message++);} // Points to one ASCII to be written one at a time.
thanks in advance
