jeanxxx
Newbie level 3
Hi guys,
I'm currently using a PIC18F4431(I've used a PIC16F877A before).
My design is very simple, a 20MHz crystal with 2 15pF caps and 8 LEDs at PortB.
Vdd, AVdd and MCLR pins are pulled to 5V and Vss, AVss pins are pulled to ground.
I've written the software using ASM and programmed it using MPLAB ICD 2
I've set the __CONFIG 1H register such that the chip is operating in HS mode.
However, when I power up, the chip won't start at all. I tried to look at the signal at the OSC2/CLKO pin and I find that there isn't any clock pulse generated by the internal oscillator.
Later on, I tried to put a cap from Vdd to GND but still it refused to start up. :x
Can anyone give me any advice on how to solve this? Any feedback will be much appreciated. :sm27:
Thanks in advance.
Regards,
Jean
Thanks in advance.
Regards,
Jean
