[SOLVED] Pic18f2550 - internal pullup
vixy
Newbie level 2
Hello,
I am using mikroC for programming PIC uC. I would like to set internal pullup at pins of PORTB, but I have a problem with instruction OPTION_REG.F7 = 0;.
Returned error: Undeclared identifier 'OPTION_REG' in expression
How can I solve this problem?
PORTB pullups are enabled by bit RBPU in INTCON2 register. I can't imagine that it's renamed to "OPTION_REG" in mkroC. Where did you get the idea?
Reactions: vixy
    vixy
on the Internet... I think that this instruction is valid, becous it works added manualy in some example projects like PortExpander
---------- Post added at 10:01 ---------- Previous post was at 09:59 ----------
Haha - you're great!
Intcon2.rbpu = 0;
works perfectly - thank you a lot :)
can I enable pullup resister in port E or C for p18f452
I cant find anything like those in data sheet
