PIC18F2550 and problem with VDD
georgz
Full Member level 1
space
Hi, i'm using this uC and i'm dealing with a strange problem... I'm building a led globe and it's working great, i'm using 2 contacts for the VDD(5V) and VSS(GND) on a disk made of PCB. So there are wires which make the contacts on the disks' rails and my problem is that for a moment there must be a disconnection between the contacts and my uC does not restart itself. I must turn the power off and the on to start working again. There is a resistor on the MCLR pin. What might cause this problem??
Your pcb disc contacts are always going to be electrically 'dirty', paricularly for a high speed micro needing a good supply
Lots of things could be done, but to keep it simple first try these two things
Put a large, 1000 or 2200 uf electrolytic cap across VDD and VSS so it holds the voltages for longer.
Fit a 100nf between Mclre and 0v, with the Pull up resistor of 10k, this should help Reset the Pic when power is restored.
If that fails perhaps try a rechargeable 4.5v battery connected to Vdd and the power source just feeding the batterys charger.
Reactions: georgz
    georgz
