PIC18F1220 RB2 not becoming input
Tiwana6330
Member level 1
Hi. I have run into a strange problem. I am using PIC18LF1220. The microcontroller is working fine except pin RB2. I have configured RB2 as input but it always reads 0 volts. To eliminate possibility of (hardare) PCB problem, I bent the RB2 pin so now its not touching the PCB. Then I am applying 3.3 volt directly from power supply to the pin. However, the pin is not registering that as high. I have also tried changing the chip. Code is below
#include <hitech.h>
 #include <pic18.h>
 void main (void)
    ADCON0 = 0x00;
 ADCON1 = 0x7F; // 7F Configure all ports with analog function as digital
 INTCON=0;
 TRISB = 0b11111111; //makes Bport input
 TRISA = 0b00000000; //makes A port output
 PORTA=0;
 while (1)
 if (RB2==1)
 RA0=1;
 else
 RA0=0;
note that other pin on PortB (RB0) is working fine as input
Can anyone please help. I think I am missing something in config bits
Read the datasheet again, you'll find why it doesn't works on pin RB2.
RB0 can be configured as analog pin.
But RB2 cannot be . Thats why it doesn't works.
Best wishes :)
Best wishes :)
I am trying to set RB2 as digital I/O not as analog. Any other ideas why it would not work?
What version of the HiTech PICC18 Compiler are you using?
The more recent versions only require the inclusion of the following header file:
#include <htc.h>
Not:
#include <hitech.h>
#include <pic18.h>
Reference: PIC18F1220/1320 Datasheet, Section: 10.2 PORTB, TRISB and LATB Registers, Page: 90
Pins RB0-RB2 are multiplexed with INT0-INT2; pins
RB0, RB1 and RB4 are multiplexed with A/D inputs;
pins RB1 and RB4 are multiplexed with EUSART; and
pins RB2, RB3, RB6 and RB7 are multiplexed with
ECCP.
Although, according to the datasheet the CCP1CON should be cleared on POR, you might try manually clearing it which should disable the ECCP module.
Also, as there is no indication of the Configuration Register state, you need to ensure the watchdog timer has been disabled.
Otherwise, the device will continually Reset which would prevent the RA0 from being set high for any significant duration.
BigDog
