dineshjpr14
- Joined
- Jun 24, 2014
- Messages
- 5
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 49
I used MPLAB 8.76 for my program. It used to build successfully and run on controller.
I have the source code and working Hex file. I used Hitech Compiler for Pic18f46k80.
After two years, i have formatted my computer. When i again to try build my program
it does build successfully, but hex file is not running and my seven segment display not
working. Hardware is ok, i checked with old Hex file.
What could be reason for this behavior? I changed my configruation bits by reading
loading old hex file. And every setting matches. But when i compile it the new hex
file doesnt run.
One more observation is that size of nex hex file is coming 42 kB and size of old hex file
was 57 KB.
Please help? i am unable to use even i have source code and everything.
I have old compiled source code folder saved in rar file. So if any could suggest
solution to see .lst file or .map file, please do so.
file doesnt run.
was 57 KB.
