PIC18 soldering temperature (manual)
neoaspilet11
Full Member level 5
Cebu, Philippines
pic18f4620 soldering
Hello friends,
ANybody knows what the soldering temperature datasheet specs for PIC18F67J11, the specs does not specify the temperatures.
I am having troubles with this manual soldering even on industry grade PCB. got two pics exibihit diffrent damage on sodlering.
Any idea with the soldering temp specs?
Neo
solder temperature pic18
You can refer to **broken link removed** as IPC/JEDEC J-STD-020C standard.
Depending on the soldering technique, manual soldering may be either rather gentle (pin-by-pin with an iron) or potential dangerous (using a small hot air tool, that's likely to overheat a device). Furthermore, the dry storage respectively necessary baking procedures for thin packages with limited floor lifetime have to be observed, also in prototyping. Otherwise package delamination may occur.
