PIC18 & Interrupt Problem
Sobakava
Full Member level 6
pic18 interrupt routin
CCS 3.148:
I am porting a 16F877 code to 18F452 but
it seems my program has problems with
interrupts.
Only RB0 EXT0 interrupt enabled. I send
"ISR" string for debugging from serial port
at the start of #INT_EXT.
Program sends ISR string continuously
even the RB0 is connected to GND and there is
no level change.
What's wrong?
pic18 low interrupt
Maybe this can help you.
PIC17CXXX to PIC18CXXX Migration: **broken link removed**
You can try to look here as well. Migrating Designs from PIC16C74A/74B to PIC18C442: **broken link removed**
PIC16 to PIC18 Code Conversion Techniques:
Copied from 00726a.pdf:
External Interrupts
For the PIC17CXXX, the INT interrupt had its own vector
address. In the PIC18CXXX, it is part of the peripheral
interrupts vector address. This means that the INT
interrupt code will need to be moved into the general
peripheral interrupt service routine (ISR), and this routine
will need to add a check for the INT interrupt
source.
The PIC18CXXX family has some enhancements for
the external interrupts. First, there are now three external
interrupt pins, as opposed to one pin in the
PIC17CXXX family. Second, enhancements to the
architecture of the interrupt logic allows additional
capability (High/Low priority). These enhancements
are discussed in the section “Architectural Enhancements”
interrupts external in pic18
This might not be right but if RB0 is connected to a switch. then you will have to implement a protocol to debounce it otherwise rattling of the switch is sufficient enough to to send your program in ISR all the time.
pic18 int_ext
RB0 is connected to another chip in my system and the other
chip generated interrupt if data is ready. PIC16F877 is success
with same hardware...
