PIC16F946 code to measure time between two edges
I am nor familiar with the architecture of your specific controller, but generally you could do it like this
Prescale your timer 0 to a desired value
Setup interrupt on RB0 to positive edge
In interrupt routine do this
read timer 0 into a variable, say "t"
clear timer 0
now compute this
    char t = get_timer0();
    float time = ((t * [your prescaler]) / (crystal_value/4); //this time is in seconds
I am now trying with CCP,how to save old time and subtract with new value.
If possible can you give me code to configure CCP and to measure time between two edges...8-O
is below code is correct????
int CCP1
void isr(void)
value = value-CCPR1; //CCPR1 holds the new time
Please refer to "PIC Microcontrollers and Embedded Systems Using Assembly and C" by Muhammed Ali Mazidi. It has an example of that.
http://www.microdigitaled.com/PIC/Code/PIC_codes.htm
file 15-3C
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
CCP1CON=0x05;
    T3CON=0x0;
    T1CON=0x0;
    TRISB=0;
    TRISD=0;
    TRISCbits.TRISC2=1;
    CCPR1L=0;
    CCPR1H=0;
  while(1)
    TMR1H=0;
    TMR1L=0;
    PIR1bits.CCP1IF=0;
    while(PIR1bits.CCP1IF==0);
    T1CONbits.TMR1ON=1;
    PIR1bits.CCP1IF=0;
    T1CONbits.TMR1ON=0;
    PORTB=CCPR1L;
    PORTD=CCPR1H;
