egg-400
Newbie level 2
Hi!
I'm just starting out wit PIC microcontrollers programming in C code. My objective was to interface the PIC with an external 32K paralell RAM (I used three ports for this) and send data through RS232 to a computer. My execution goes like this. First the PIC reads from ADC a 10bit value, puts it to two addresses in the RAM (RAM is 8-bit) and when we have read the specified amount of data the PIC reads the data from RAM and sends it to a computer via RS232. So, everything is working fine except for one detail, every 32:nd word gets corrupted when sent to the computer and I just can't find any reason for that? Can anyone with greater knowledge perhaphs find the problem? I've narrowed it down that the read_adc() function always reads a value < 1024 so there's no problem with that one. The corrupted word is also always in relation to the words just before and after. Example adc reads a value of 10, 1000times and every 32 word is now about 4000 but all the 10's are correct. The value 350 is read 1000 times and every 32 is now about 21300. Maybe my code could enlighten things.
#include <16F887.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP,NODEBUG
#device ADC=10
#use delay(clock=16000000)
#use rs232(baud=38400, xmit=PIN_A2, rcv=PIN_A1,INVERT,LONG_DATA)
#include <stdlib.h>
void send(int16 amount);
void read(int16 size);
int16 data=0,n=2,lowword=0,highword=0,sendword,i;
int j,k,l,m;
char* str[5];
void main() {
setup_adc(ADC_CLOCK_DIV_32);
setup_adc_ports(sAN0);
set_adc_channel(0);
while(1){
output_high(PIN_A3); //LED
if(input_state(PIN_A4)){
read(1000);
delay_ms(500);
send(1000);
void read(int16 size){
output_high(PIN_E0); //LED
output_low(PIN_E1); // write enable for RAM
output_low(PIN_E2); //
for(i = 0; i < size; i++){
j = i>>8;
k = i & 0xFF;
OUTPUT_B(k); //Address
OUTPUT_C(j);
if(n != 2){
m = data & 0xFF;
OUTPUT_D(m);
else{
data = read_adc();
l = data >> 8;
OUTPUT_D(l);
n=0;
n++;
output_low(PIN_E0);
void send(int16 amount){
output_high(PIN_A5); //LED
output_low(PIN_E2); // Read enable for RAM
output_high(PIN_E1); //
for(i = 0; i < amount; i++){
j = i>>8;
k = i & 0xFF;
OUTPUT_B(k); //address
OUTPUT_C(j);
if(n != 2){
lowword = INPUT_D();
sendword = lowword | highword;
//if(sendword < 1025){
itoa(sendword,10,str);
puts(str);
else{
highword = INPUT_D();
highword = highword << 8;
n=0;
n++;
output_low(PIN_A5); //LED
A very easy but BAD solution would be to interpolate every 32:nd word from previous and next before sending it.
#include <16F887.h>
#device ADC=10
#include <stdlib.h>
int j,k,l,m;
char* str[5];
void main() {
set_adc_channel(0);
while(1){
read(1000);
delay_ms(500);
send(1000);
j = i>>8;
k = i & 0xFF;
OUTPUT_C(j);
if(n != 2){
m = data & 0xFF;
OUTPUT_D(m);
else{
data = read_adc();
l = data >> 8;
OUTPUT_D(l);
n=0;
n++;
output_low(PIN_E0);
j = i>>8;
k = i & 0xFF;
OUTPUT_C(j);
if(n != 2){
puts(str);
else{
n=0;
n++;
