Tamim Neak
Junior Member level 1
- Joined
- Feb 15, 2015
- Messages
- 18
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 137
hi all i have the following code
i am trying to control the spwm based on the battery voltage. The following portion of the code gets executed only once. i want it to execute at the end of each sin cycle so that the spwm is updated based on the value of battery voltage. any help is appreciated.
const unsigned char sin_table[576]={
0, 6, 12, 18, 24, 30, 36, 42, 48, 53, 59, 64, 69, 74, 79, 84, 88, 93, 97, 100, 104, 107, 110, 113, 115, 118, 120, 121, 123, 124, 124, 125, 125, 125, 124, 124, 123, 121, 120, 118, 115, 113, 110, 107, 104, 100, 97, 93, 88, 84, 79, 74, 69, 64, 59, 53, 48, 42, 36, 30, 24, 18, 12, 6,
//0, 6, 11, 17, 23, 28, 34, 39, 44, 50, 55, 60, 64, 69, 74, 78, 82, 86, 90, 93, 96, 99, 102, 105, 107, 109, 111, 113, 114, 115, 115, 116, 116, 116, 115, 115, 114, 113, 111, 109, 107, 105, 102, 99, 96, 93, 90, 86, 82, 78, 74, 69, 64, 60, 55, 50, 44, 39, 34, 28, 23, 17, 11, 6, //92.8%
0, 5, 11, 16, 22, 27, 32, 37, 42, 47, 52, 57, 62, 66, 70, 75, 78, 82, 86, 89, 92, 95, 98, 100, 103, 105, 106, 108, 109, 110, 110, 111, 111, 111, 110, 110, 109, 108, 106, 105, 103, 100, 98, 95, 92, 89, 86, 82, 78, 75, 70, 66, 62, 57, 52, 47, 42, 37, 32, 27, 22, 16, 11, 5, //88.8%
0, 5, 10, 16, 21, 26, 31, 36, 41, 45, 50, 54, 59, 63, 67, 71, 75, 79, 82, 85, 88, 91, 93, 96, 98, 100, 101, 103, 104, 105, 105, 106, 106, 106, 105, 105, 104, 103, 101, 100, 98, 96, 93, 91, 88, 85, 82, 79, 75, 71, 67, 63, 59, 54, 50, 45, 41, 36, 31, 26, 21, 16, 10, 5, //84.8%
0, 5, 10, 15, 20, 25, 30, 34, 39, 44, 48, 52, 57, 61, 65, 68, 72, 76, 79, 82, 85, 87, 90, 92, 94, 96, 98, 99, 100, 101, 102, 102, 102, 102, 102, 101, 100, 99, 98, 96, 94, 92, 90, 87, 85, 82, 79, 76, 72, 68, 65, 61, 57, 52, 48, 44, 39, 34, 30, 25, 20, 15, 10, 5, //81.6%
0, 5, 10, 14, 19, 24, 28, 33, 38, 42, 46, 50, 54, 58, 62, 66, 69, 73, 76, 79, 81, 84, 86, 89, 91, 92, 94, 95, 96, 97, 98, 98, 98, 98, 98, 97, 96, 95, 94, 92, 91, 89, 86, 84, 81, 79, 76, 73, 69, 66, 62, 58, 54, 50, 46, 42, 38, 33, 28, 24, 19, 14, 10, 5, //78.4%
0, 5, 9, 14, 18, 23, 27, 32, 36, 40, 44, 48, 52, 56, 60, 63, 66, 70, 73, 76, 78, 81, 83, 85, 87, 89, 90, 91, 92, 93, 94, 94, 94, 94, 94, 93, 92, 91, 90, 89, 87, 85, 83, 81, 78, 76, 73, 70, 66, 63, 60, 56, 52, 48, 44, 40, 36, 32, 27, 23, 18, 14, 9, 5, //75.2%
0, 4, 9, 13, 18, 22, 26, 31, 35, 39, 43, 47, 51, 54, 58, 61, 64, 67, 70, 73, 76, 78, 80, 82, 84, 86, 87, 88, 89, 90, 91, 91, 91, 91, 91, 90, 89, 88, 87, 86, 84, 82, 80, 78, 76, 73, 70, 67, 64, 61, 58, 54, 51, 47, 43, 39, 35, 31, 26, 22, 18, 13, 9, 4, //72.8%
0, 4, 9, 13, 17, 21, 26, 30, 34, 38, 41, 45, 49, 52, 56, 59, 62, 65, 68, 71, 73, 75, 78, 80, 81, 83, 84, 85, 86, 87, 88, 88, 88, 88, 88, 87, 86, 85, 84, 83, 81, 80, 78, 75, 73, 71, 68, 65, 62, 59, 56, 52, 49, 45, 41, 38, 34, 30, 26, 21, 17, 13, 9, 4, //70.4%
0, 4, 8, 12, 17, 21, 25, 29, 33, 36, 40, 44, 47, 51, 54, 57, 60, 63, 66, 68, 71, 73, 75, 77, 79, 80, 81, 82, 83, 84, 85, 85, 85, 85, 85, 84, 83, 82, 81, 80, 79, 77, 75, 73, 71, 68, 66, 63, 60, 57, 54, 51, 47, 44, 40, 36, 33, 29, 25, 21, 17, 12, 8, 4 //68%
unsigned int TBL_POINTER_NEW, TBL_POINTER_OLD, TBL_POINTER_SHIFT, SET_FREQ, adder,FB_Step;
unsigned int TBL_temp;
unsigned char DUTY_CYCLE;
unsigned int temp;
unsigned int battery_voltage;
void interrupt(){
if (TMR2IF_bit == 1){
TBL_POINTER_NEW = TBL_POINTER_OLD + SET_FREQ;
if (TBL_POINTER_NEW < TBL_POINTER_OLD){
CCP1CON.P1M1 = ~CCP1CON.P1M1; //Reverse direction of full-bridge
TBL_POINTER_SHIFT = TBL_POINTER_NEW >> 10;
DUTY_CYCLE = TBL_POINTER_SHIFT + adder;
CCPR1L = sin_table[DUTY_CYCLE];
TBL_POINTER_OLD = TBL_POINTER_NEW;
TMR2IF_bit = 0;
void Run_PWM(){
PORTC = 0;
PORTD = 0;
SET_FREQ = 1024;
TBL_POINTER_SHIFT = 0;
TBL_POINTER_NEW = 0;
TBL_POINTER_OLD = 0;
DUTY_CYCLE = 0;
adder = 0;
FB_Step = 0;
ECCPAS =0b11000000; //autoshutodwm on INT pin high
PR2 = 0b01111100; //124
CCP1CON = 0b01001100; // duty lowest bits + PWM mode
TMR2IF_bit = 0;
T2CON = 4; //TMR2 on, prescaler and postscaler 1:1
while (TMR2IF_bit == 0);
TMR2IF_bit = 0; // Timer2 interrupt flag
TRISC = 0;
TMR2IE_bit = 1; //interrupt when TMR2 matches PR2
GIE_bit = 1; // Global interrupt enabled
PEIE_bit = 1; // peripheral interrupt enabled
PWM1CON = PWM1CON + 0b10000000 ; //Part of ECCPAS procedure
void main() {
ANSEL = 0x0F;
ANSELH = 0x00;
ADCON1 = 0x80;
TRISA=0b00000001;
CM1CON0 = 0; //Disable Comparator
CM2CON0 = 0;
TRISC = 0;
TRISD = 0;
TRISB = 1;
PORTC = 0;
PORTD = 0;
PORTB = 0;
ADC_Init();
battery_voltage = ADC_read(0);
FB_Step = floor((battery_voltage - 750)/35);
adder = FB_Step << 6; //2^6 =64
while( PORTB.F0 == 0);
Run_PWM();
while(1);
