crAsh_
Newbie level 2
Hi all,
I would appreciate if someone familiar with 16F886 could assist me.
Basically i'm trying to transmit data which is just based on a push button respond and ouput it through TX pin of 16F886 and to Xbee S1 DIN and light up a led on the receiver side. However i am unable to transmit any data at all. I am using MPLAB 8.7
Below is my TX program:
list p=16f886 ; list directive to define processor
#include <p16f886.inc> ; processor specific variable definitions
; '__CONFIG' directive is used to embed configuration data within .asm file.
; The labels following the directive are located in the respective .inc file.
; See respective data sheet for additional information on configuration word.
__CONFIG _CONFIG1, _LVP_OFF & _FCMEN_ON & _IESO_OFF & _BOR_OFF & _CPD_OFF & _CP_OFF & _MCLRE_ON & _PWRTE_ON & _WDT_OFF & _INTRC_OSC_NOCLKOUT
__CONFIG _CONFIG2, _WRT_OFF & _BOR21V
; example of using Shared Uninitialized Data Section
INT_VAR UDATA_SHR
w_temp RES 1 ; variable used for context saving
status_temp RES 1 ; variable used for context saving
pclath_temp RES 1 ; variable used for context saving
; example of using Uninitialized Data Section
TEMP_VAR UDATA ; explicit address specified is not required
temp_count RES 1 ; temporary variable (example)
RESET_VECTOR CODE 0x0000 ; processor reset vector
nop
goto start ; go to beginning of program
INT_VECTOR CODE 0x0004 ; interrupt vector location
INTERRUPT
movwf w_temp ; save off current W register contents
movf STATUS,w ; move status register into W register
movwf status_temp ; save off contents of STATUS register
movf PCLATH,w ; move pclath register into w register
movwf pclath_temp ; save off contents of PCLATH register
; isr code can go here or be located as a call subroutine elsewhere
movf pclath_temp,w ; retrieve copy of PCLATH register
movwf PCLATH ; restore pre-isr PCLATH register contents
movf status_temp,w ; retrieve copy of STATUS register
movwf STATUS ; restore pre-isr STATUS register contents
swapf w_temp,f
swapf w_temp,w ; restore pre-isr W register contents
retfie ; return from interrupt
; Transmitter side
; PORT Initialization
BANKSEL PORTA ;
CLRF PORTA ; Init PORTA
BANKSEL ANSEL ;
CLRF ANSEL ; digital I/O
BANKSEL PORTC ;
CLRF PORTC ; Init PORTC
BANKSEL ANSEL ;
BCF STATUS,RP1 ; bank 1
banksel TRISA
movlw 0xFF ; set PORTA as input
movwf TRISA
movlw 0x00 ; set PORTC as output
movwf TRISC
; UART Initialization
banksel SPBRG ; select bank1
movlw 0x19 ; baudrate = 9600K
movwf SPBRG ; load baudrate config. into SPBRG register
movlw b'00100100' ; TXEN = 1, BRGH = 1, Asynch. mode
movwf TXSTA ; load the value into TXSTA register
banksel RCSTA ; select bank0
movlw b'10000000' ; SPEN = 1 configures TX pin as output
movwf RCSTA ; load the values into RCSTA register
bcf STATUS,5 ; return to bank 0
; Main Programme
MAIN_PROG CODE
start
again call get_input
call transmit
goto again
; Get Input
get_input
wait btfsc PORTA, 0 ; read PORTA bit 0. if input=0, proceed else wait
goto wait
movf PORTA, W ; move values in PORTA to W register
return
; Transmit Data
transmit
send movwf TXREG ; transmit data stored in W register
banksel TXSTA
busy btfss TXSTA,TRMT ; check if transmission completed
goto busy
bcf STATUS, 5
return
; example of preloading EEPROM locations
EE code 0x2100
DE 5,4,3,2,1
END ; directive 'end of program'
Is there any configuration that i have missed out? btw I am using the default oscillator which is at 4MHz, do i also need to configure OSCON register?
Appreciate your help.
Newbie here.
INT_VAR UDATA_SHR
nop
INTERRUPT
swapf w_temp,f
; Transmitter side
BANKSEL PORTA ;
BANKSEL ANSEL ;
BANKSEL PORTC ;
BANKSEL ANSEL ;
banksel TRISA
movwf TRISA
movwf TRISC
; Main Programme
MAIN_PROG CODE
start
call transmit
goto again
; Get Input
get_input
goto wait
return
; Transmit Data
transmit
banksel TXSTA
goto busy
bcf STATUS, 5
return
EE code 0x2100
DE 5,4,3,2,1
Newbie here.
