#include <HDM64GS12.c>
#include <graphics.c>
#include <math.h>
#byte trisa=0x85
#byte trisb=0x86
#byte trisc=0x87
#byte trisd=0x88
#byte trise=0x89
#byte porta=0x05
#byte portb=0x06
#byte portc=0x07
#byte portd=0x08
void displayVoltage(int adc) {
char voltage[9];
sprintf(voltage, "%f", (float)adc * .01960784); // Converts adc to text
voltage[4] = '\0'; // Limit shown digits to 3
glcd_rect(45, 18, 69, 25, YES, OFF); // Clear the old voltage
glcd_text57(45, 18, voltage, 1, ON); // Write the new voltage
void main() {
int1 warn = FALSE;
int8 adc = 0, adc_old = 0;
char voltText[] = "VoLtS\0", warning[] = "Warning";
float theta = 0;
setup_adc_ports(RA0_ANALOG);
setup_adc(ADC_CLOCK_INTERNAL);
set_adc_channel(0);
TRISA = 0x00;
TRISB = 0x00;
TRISC = 0x00;
TRISD = 0x00;
TRISE = 0x00;
porta=0x00;
while(1)
glcd_init(ON); // Must initialize the LCD
//glcd_rect(1, 1, 126, 126, YES, ON); // Outline the bar
glcd_text57(50, 100, voltText, 1, ON); // Display "Volts"
glcd_circle(30,47, 10, NO, ON); // Draw the clock circle
porta=~porta;
delay_ms(300);
// for(;;) {
adc = read_adc(); // Read a value from the ADC
displayVoltage(adc); // Display the reading
adc = (adc > 249) ? 249 : adc; // Keep the value 249 or less
if(adc != adc_old) {
glcd_rect(adc/2+1, 6, adc_old/2+1, 14, YES, OFF); // Clears the old bar
glcd_rect(1, 6, adc/2+1, 14, YES, ON); // Draws a new bar
adc_old = adc; // Set old value to new
if(adc > 200 && !warn) { // Check if over 4 volts
glcd_rect(45, 38, 124, 55, YES, ON); // Draw a filled black rectangle
glcd_text57(47, 40, warning, 2, OFF); // Write "Warning" on the LCD
warn = TRUE; }
else if(adc <=200 && warn) {
glcd_rect(45, 37, 125, 55, YES, OFF); // Draw a filled white rectangle
warn = FALSE; }
// The following 3 lines make the clock hand spin around
glcd_line(30, 47, 30+(int)(8*sin(theta)+.5), 47-(int)(8*cos(theta)+.5), OFF);
theta = (theta > 5.9) ? 0 : (theta += .3);
glcd_line(30, 47, 30+(int)(8*sin(theta)+.5), 47-(int)(8*cos(theta)+.5), ON);
#ifdef FAST_GLCD
glcd_update();
#else
delay_ms(100); // Reduces flicker by allowing pixels to be on
// much longer than off
#endif
