OpenNX error (SSH) - DISPLAY NOT DEFINED
lufer17
Member level 5
Member level 5
Putty error (SSH) - DISPLAY NOT DEFINED
Hello everyone, I'm having trouble doing remote access because the following message '' 'DISPLAY <NOT DEFINED>' '' appears, since I have installed Xming.
Re: Putty error (SSH) - DISPLAY NOT DEFINED
try adding
-display localhost:0
to commandline .
does the xming installation works without problem
as a standalone server?
1- Xming is working normally, yes.
2- did not answer for sure, but I believe so.
please post on the environments you use.
xming system and system NXclient is communicating.
Look, please
ensure that xming is working as standalone without problem by running
an xapp like xeyes etc.
if it is runing ok , connect opennx with appropriate proxy settings.
*WARNING* X Window Display Initialization failure
*WARNING* (DISPLAY "localhost:15.0")
??????i can't.....now
suggested basic configuration:
display settings:multiplewndows/display=0
session:noclient
additionalparameters:clipboard in 'xlaunch'
session:noclient
did not work
try display field as -127.0.0.1:0
if not working it can be due to multiple monitor issue or some other
display driver mismatch in xming .
