[PIC] PIC16f877A UART char read error
go ahead
Junior Member level 1
I am using PIC16F877A with the Bluetooth module (HC-05) in UART . problem is that when i get a char from UART and send it to PORTB then its shows some value in 0 and 1.
but i wanted to check, what char it is then its not working. :x
i have tried as a char like
if RCREG=='A' but its not working and when i tried from comparing by char's ASC codes but still its not working. in ASC i compare like if RCREG==0x41 (for A).
the task i wanted to perform simple task like-
if its gets A on UART then glow led on RB7 for some time than turn it off.
if its gets B on UART then glow led on RB6 for some time than turn it off and so on.
and my code is written in MPLAB.
thanks in advance :grin:
#include<htc.h>
#define _XTAL_FREQ 8000000
void Delay500Us()
unsigned char cnt500Us = 165;
while(--cnt500Us != 0) //
continue;
//100 msec Delay function
void Delay100ms()
unsigned char cnt100ms = 200; // 200 * 500 Usec = 100 msec
do
Delay500Us();
}while(--cnt100ms != 0);
//1 sec Delay function
void Delay1s()
unsigned char cnt1ms = 10; //10 * 100 msec = 1 sec
do
Delay100ms();
}while(--cnt1ms != 0);
char UART_Init()
SPBRG = 25; //Writing SPBRG register
SYNC = 0; //Selecting Asynchronous Mode
SPEN = 1; //Enables Serial Port
TRISC7 = 1;
TRISC6 = 0;
RCIE =1;
TX9= 0;
RX9= 0;
CREN = 1; //Enables Continuous Reception
TXEN = 1;
TXEN = 1; //Enables Transmission
char UART_Data_Ready()
return RCIF;
char UART_Read()
while(!RCIF);
return RCREG;
void UART_Write(char data)
while(!TRMT);
TXREG = data;
void UART_Write_Text(char *text)
int i;
for(i=0;text!='\0';i++)
UART_Write(text);
void UART_Read_Text(char *Output, unsigned int length)
int i;
for(int i=0;i<length;i++)
Output = UART_Read();
void main()
unsigned int temp;
TRISB = 0x00; //PORTB as Output
UART_Init();
Delay100ms(1);
while(1)
if(UART_Data_Ready())
temp= UART_Read(RCREG);
if(temp=='A')
RB0=0;
Delay100ms(10);
RB0=1;
if(temp=='B')
RB1=0;
Delay100ms(10);
RB1=1;
if(temp=='C')
RB2=0;
Delay100ms(10);
RB2=1;
if(temp=='D')
RB3=0;
Delay100ms(10);
RB3=1;
//PORTB = UART_Read();
//Delay100ms(10);
hello
UART_Read don't need RCREG as parameter ! it' return RCREG
and UART_Read is allready waiting for RCIF==1
so use direct test
so
while(1)
 temp=UART_READ();
.. etc ....
at the end of tests
clear flags Frame FERR and OVER
You have to clear RCIF in UART_Read_Text() function. Add RCIF = 0; as last line of UART_Read_Text().
