pic16f877a timer0 c programming
omkardespande
Newbie level 5
Friends/sirs,
I am trying to get the frequency of external clock pulse to displayed on LCD using pic16f877a in Hi-Tech PICC 9.82 c compiler. Following is the program:-
********************************XXXXX************************************************
#include<pic16f877a.h>
#define ldata PORTB
#define rs PORTCbits.RC0
#define en PORTCbits.RC1
void Display_Freq(unsigned int freq2write) ;
void Lcd_Cmd(unsigned char value);
void Lcd_display(unsigned char value);
void delay_lcd(unsigned int time);
void delay();
const char txt1[10]="Frequency=\n";
const char txt2[10] = "Hz\n";
const char txt3[20] = "Out of Range\n";
//const char txt4[30] = "Wind speed>53Kn\n "
int i;
unsigned char freq[6] ;
void main()
PORTAbits.RA4 = 1;
TRISB = 0x00;
TRISC = 0x00;
Lcd_Cmd(0x38); //LCD initialize
delay();
Lcd_Cmd(0x0c);
delay();
Lcd_Cmd(0x01);
delay();
Lcd_Cmd(0x06);
delay();
Lcd_Cmd(0x80);
delay();
for(i=0;i<10;i++)
Lcd_display(txt1);
OPTION_REG = 0x00;
OPTION_REGbits.PS0=0;
OPTION_REGbits.PS1=0;
OPTION_REGbits.PS2=0;
OPTION_REGbits.PSA=1;
OPTION_REGbits.T0SE=0;
OPTION_REGbits.T0CS=1;
delay();
while(1)
TMR0=0;
INTCON = 0B00100000;
delay();
if(INTCONbits.TMR0IF)
Lcd_Cmd(0x80);
delay();
for(i=0;i<20;i++)
Lcd_display(txt3);
delay();
Display_Freq(TMR0);
freq[0] = (freq2write/1000)+48 ;
freq[1] = (freq2write/100)%10+48 ;
freq[2] = (freq2write/10)%10+48;
freq[3] = freq2write%10+48 ;
Lcd_Cmd(0x86);
for(i=0;i<5;i++)
Lcd_display(freq);
Lcd_Cmd(0x8A);
delay();
for(i=0;i<10;i++)
Lcd_display(txt2);
ldata = value;
rs = 0;
en = 1;
delay_lcd(30);
en = 0;
ldata = value;
rs = 1;
en = 1;
delay_lcd(30);
en = 0;
unsigned int i,j;
for(i=0;i<time;i++)
for(j=0;j<135;j++);
void delay()
unsigned i;
for(i=0;i<10000;i++);
The problem is I am not getting the right value inside TMR0 register, when I apply signal to RA4 pin. Means if i give the clock pulse of 151Hz, it shows something 22Hz. But when I directly assign some value to TMR0 in while() loop, it displays correctly that value. I dont understand, whether my program is correct or not. Because when i do this program in mickro C, it works absolutely fine. I just copied that in mplab & added the functions. That it, but still unable to get it. Please help me out.
Thank You.
here is the attachment.
  • Project files.zip
I thinks your delay function is not same.
This code is display number signals is received. You need calculate freq from that value.
Oh....I got it. Now, its working.. :) Thanks a lot.!!
