mnqobilozo
Newbie level 3
- Joined
- Sep 2, 2014
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 39
i am designing a UPS for a school project using a PIC16F877A as a controller to monitor the temperature by displaying temperature on a 2X16 LCD and run a motor if a temperature of 70 degrees is reached and stops when the temperature drops to 50 degrees. i also inserted a voltage detector to detect an output on the inverter and send a 5 volts signal to PIN_B2 of the pic if voltage is present, so that if there is no voltage, the pic should switch a relay through PIN_B4 to supply the load from the mains supply bypassing the UPS.
i have succeeded on the other tasks but i fail to switch the relay accordingly.
here is my program written in C language using CCS compiler.
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 /* PIC16F877A and LM35 Based Temperature Monitor MACHI M.C STD.no 20403715 */ #include <16f877a.h> #device adc=10 // Set ADC resolution to 10Bit #fuses XT,NOLVP,NOWDT,NOPROTECT #use delay(crystal=4000000) #use rs232(baud=960,xmit=PIN_C6,rcv=PIN_C7,ERRORS) #include <lcd.c> #define LOAD PIN_B7 #define THRES 70.0 // load switching threshold in Celsius #define OFF 50.0 // fan stops when temparature reaches value in degrees #define ADC_OFF 0 // ADC off #define RELAY PIN_B4 #define R2 PIN_B2 #define R1 PIN_B1 #include <stdlib.h> int16 digital_reading; // ADC resolution is 10Bit, an 8Bit integer is not enough to hold the reading float temp; void main() { /* ADC Initialization */ setup_adc(ADC_CLOCK_INTERNAL); // initialize ADC with a sampling rate of Crystal/4 MHz setup_adc_ports(RA0_ANALOG); // set PIN_A0 as analog input channel set_adc_channel(0); // point ADC to channel 0 for ADC reading delay_ms(1); // ADC module is slow, needs some time to adjust. disable_interrupts(GLOBAL); // DISABE ALL INTERRUPTS. SET_TRIS_B(0X0F); //set RB0,RB1,RB2 & RB3 as inputs, RB4,RB5,RB6 & RB7 as output. output_low(RELAY); // relay initialy off if (input(PIN_B2)==0) { output_high(PIN_B4); } else if (input(PIN_B2)==1) { output_low(RELAY); } /* Peripherals Configurations */ lcd_init(); // Turn LCD ON, along with other initialization commands output_low(LOAD); // the load is initially OFF lcd_gotoxy(1,1); // point LCD cursor to col1 row1 lcd_putc("Temperature is:"); // print on LCD { while(1) // infinite loop { digital_reading = read_adc(); // capture current temperature reading delay_us(100); // 0.1ms delay for ADC stabilization temp = digital_reading * 0.4883; // convert reading to Celsius lcd_gotoxy(1,2); // point LCD cursor to col1 row2 printf(lcd_putc,"%2.1f C",temp); // print value on LCD if(temp>=THRES) Do { output_high(LOAD); // Control Load } while (temp>=OFF); else output_low(LOAD); delay_ms(1000); // 1 second delay between readings } } }
