Pic16f877a intro to relocatable code
kemalkemal
Member level 1
Member level 1
Hi all,
After one week that i've decided to learn relocatable code with assembler and after i found out solutions to problems i encounter here is my solutionless problem :)
i wrote just a simple code to load port b with b'01010101' like this.
;calling file
Code ASM - [expand]
8
9
10
11
12
13
14
15
16
list        p=16f877a
#include    <p16f877a.inc>
        __CONFIG _CP_OFF & _WDT_OFF & _BODEN_OFF & _PWRTE_ON & _RC_OSC & _WRT_OFF & _LVP_ON & _CPD_OFF
extern  prog
RESET_VECTOR    CODE    0x0000
nop                        ;
pagesel start
goto    start
INT_VECTOR      CODE    0x0004
INTERRUPT
 retfie
MAIN_PROG       CODE
start
pagesel prog
call    prog
    END                       ;
reference file
Code ASM - [expand]
8
9
10
11
12
13
14
15
16
17
18
list        p=16f877a
global port1,prog
udata
port1   res     1
MAIN_PRO       CODE
prog
banksel TRISB
clrf    TRISB
banksel port1
movlw   b'01010101'
movwf   port1
movf    port1,w
banksel PORTB
movwf   PORTB
retlw   0
    END                       ;
I build this without error , make the hex file with mpasmwin. But when i load hex into pic , i dont see 01010101 on port b of my development board.
ANy idea? Thanks.
hii
check your circuit if it is connected properly.... try it in a simulation.
if the circuit is not at all working, then check ur oscillator circuit and your CONFIG bits
You do not say what your dev board is, but generally most hobbyist programmers do not use LVP so you Must set LVP=OFF or it may not program correctly.
In Assembly you have a choice of Absolute or Relocatable code, however if you read up on relocatable code its often considered only useful for very complex coding and even then problems are often reported.
For the majority of diy projects Absolute code is much simpler and virtually all web examples and tutorial are in Absolute code.
Would strongly suggest you change over to Absolute modl in your project Options.
Here is your code reworked for Absolute mode, so much simpler , surley ?
	list p=16f877a
	__CONFIG _CP_OFF & _WDT_OFF & _BODEN_OFF & _PWRTE_ON & _RC_OSC & _WRT_OFF & _LVP_OFF & _CPD_OFF
	cblock 0x0020		; RAM LOCATION
;	port1				; bad choice of label  -use -
	work1
	endc
	ORG  0x0000 		;RESET_VECTOR
	goto start
	ORG  0x0004 		;INT_VECTOR CODE
	retfie
start					;MAIN_PROG CODE
	clrf	PORTB		;CLEAR PORTB
	banksel	TRISB
	clrf	TRISB		;SET PORTB TO OUTPUTS
	banksel	PORTB
	movlw	b'01010101'
	movwf	work1
;	movf	port1,w	   ; not needed as the value is still in W
	movwf	PORTB
loop goto	loop
	END
First I change my _RC_OSC config to _XT_OSC and then set LVP to off. And problem is solved.Thanks again.
