Ishah
Member level 1
Hi everyone,
I need your help to fix my code. I want to make project security sliding door. When the user push one button the motor will run,at the same time when the user push the button again,the motor will stop. Another case, while the motor is running,the sensor triggered and the motor will stop.
Here is my Proteus circuit and my code. I am lack of programming, but I try to learn it seem it look messy. Can anyone give some example?
My problem is the motor automatically run,stop,run without selecting any button.
Then if I make some changes
The motor static.
Here are the result:
For simulation, I used the switches as sensor.
Project Title: Controlled Motor by switches and sensor
void main()
TRISA=0XFF; //Configure all bit of PORTA as input
TRISB=0XFF; //Configure all bit of PORTB as input
TRISD=0X00; //Configure all bit of PORTD as output
PORTA=0X00; // Clear bits to zero
PORTB=0X00; // Clear bits to zero
PORTD=0X00; // Clear bits to zero
CMCON=0X07; // or CMCON register = 0X00000111
ADCON1=0X07; // Configure ADCON1, or ADCON1=0X06;
do
if(PORTB.F0 == 1) //If the switch is pressed
PORTD.F0 = 0; // Motor 1 clockwise
PORTD.F1 = 1;
PORTD.F2 = 0; // Motor 2 clockwise
PORTD.F3 = 1;
Delay_ms(1000); // Delay 100 ms
else
if (PORTB.F1 == 1) //If the switch is pressed
if(PORTB.F1 == 1) //If the switch is pressed
PORTD.F0 = 1; // Motor 1 anti-clockwise
PORTD.F1 = 0;
PORTD.F2 = 1; // Motor 2 anti-clockwise
PORTD.F3 = 0;
else
PORTD.F0 = 1; // Motor stop
PORTD.F1 = 1;
PORTD.F2 = 1; // Motor stop
PORTD.F3 = 1;
Delay_ms(500); // Delay 1000 ms
if(PORTA.F0 == 1) //If the sensor triggered
PORTD.F0 = 0; // Motor 1 stop
PORTD.F1 = 0;
PORTD.F2 = 0; // Motor 2 stop
PORTD.F3 = 0;
Delay_ms(500); // Delay 100 ms
else
if(PORTA.F1 == 1) //If the sensor triggered
PORTD.F1 = 0;
PORTD.F3 = 0;
else
PORTD.F0 = 1; // Motor 1 keep run
PORTD.F1 = 1;
PORTD.F2 = 1; // Motor 2 keep run
PORTD.F3 = 1;
while(1);
while(1);
if(PORTB.F0 == 1) //If the switch is pressed .................................
