############## MAIN #################
void
init_TMR1() {
tmr1H2 = 256-15;
TMR1IF = 0;
TMR1H = 0x3C;
TMR1L = 0xB0;
T1CON = TMR1_SET;
//=============== INITIALIze the PORTS I/O
init_system(void){
PORTA = 0;
PORTB = 0;
PORTC &= 0xC0;
PORTD = 0;
PORTE = 0;
ADCON0 = 0x85;
ADCON1 = 0b10000010;
TRISA = TRISACONF;
TRISB = TRISBCONF;
TRISC = TRISCCONF;
TRISD = TRISDCONF;
TRISE = TRISECONF;
OPTION = 0b00000000;
//========= CONFIGURE THE INTERRUPTS ==========//
PIE1 = 0b00100001;
PIE2 = 0b00000000;
RCIF = 0;
INTCON = 0b01000000;
//=========== Conversion ANA 12V =================
adc_read(ANA_12V, &ana_12v); // monitor +12V (battery)
lcd_clear();
lcd_puts("12V=");
lcd_uint(ana_12v, 4);
################ lcd.c ###################
// ANA Mode 8 bits (justify)
// returns the voltage supply 12V
unsigned char
ana12(void){
unsigned char volt;
ADGO = 1;
while(ADGO);
volt = ADRESH + (ADRESH>>3);
return volt;
//================= value ANA Mode 10bits=============
void
adc_read(unsigned char channel, unsigned int* val)
ADCON0 = (channel << 3) + 0x81;
ADGO = 1;
while(ADGO);
*val = (unsigned int)(ADRESH<<8) + ADRESL;
################### port.h ###################
#include <htc.h>
#include <pic.h>
#include <string.h>
#define FOSC 7372800L // 7.3728MHz
################## lcd.h ##################
unsigned char ana12(void);
// ANA Mode 10bits
void adc_read(unsigned char channel, unsigned int* val);
