[SOLVED] PIC16F877 RTC Not working
WStevens_sa
Member level 2
South Africa
Hi all
I wrote the code at the bottom to create a rtc using f877. The inturrupt triggers and sets the seconds minutes and hours. I have outputs RA0 and RA1.
After 60 seconds I want RA0 = 1 and after 2 minutes I want RA1 = 1 however as soon as I simulate using real pic simulator both RA0 and RA1 go on immediately. Can someone please tell me where I have gone wrong.
unsigned int counter = 0 ;
unsigned char seconds = 0, minutes = 0, hours = 0 ;
void interrupt(void) {
if(T0IF_bit == 1) // Check for interrupt flag
T0IF_bit=0;
counter++ ;
if(counter > 15625){ // 1 sec 16 Mhz crystal = 16000000 / 4 / 256
counter = 0 ;
seconds++ ;
if(seconds == 60){
seconds = 0 ;
minutes++ ;
if(minutes == 60){
minutes = 0 ;
hours++ ;
if(hours == 24){
hours = 0 ;
void main()
TMR0 = 0; //Clear timer 0
T0CS_bit = 0; //use internal clock
T0SE_bit = 0; // on rising edge
PSA_bit = 1; // use prescaler
PS1_bit = 1; // prescaler divides in 256
PS2_bit = 1;
PORTA = 0; /*set RA0-RA5 low */
TRISA = 0; /*set PORTA to output*/
PORTD = 0; /*set RA0-RA5 low */
TRISD = 0; /*set PORTA to output*/
ADCON1 = 7; //Disable ADC
//CMCON = 7; - FOR 16F877A
while(1)
if (Seconds = 59) {
RA0_bit=1;
if (Minutes = 2) {
RA1_bit=1;
---------- Post added at 09:57 ---------- Previous post was at 09:18 ----------
Okay I found my first mistake
if (Seconds = 59) {
RA0_bit=1;
Must be.
if (Seconds == 59) {
RA0_bit=1;
Same with the minutes.
I am still not sure if this is working as a true RTC. I hope someone can answer me on this.
Hi WStevens, first of all I'm learning MCU programming so I could be wrong. Anyway, this is the ISR code I used with the same microprocessor (f877A) to simulate a clock, last year, with an external clock (Xtal=20MHz), prescaler=32, TMR0 (preload time) =100 (it should be 102 but, trying and retrying, I've seen that 100 was the best). It's not very precise but, for learning and simulating a RCT, it's ok. Well, I see that your code is a copy of mine, the one difference I note is I put TOIF=0 almost at code end. Pratically, I close routine (TOIF= 0) after all counting, not before. Try in this way... I'll be waiting for an answer.
void interrupt isr(void)
if (T0IF)
TMR0=100;
// CLOCK MANAGEMENT
counter++;
if (counter==1000)
{ counter=0;
seconds++;
if (seconds>59)
{ seconds=0;
minutes++;
if (minutes>59)
{ minutes=0;
hours++;
if (hours>23)
{ hours=0;
T0IF=0;
Hi I actually figured it out. Here is my code for creating a Real Time clock using PIC16F877 with a 2x16 character LCD using TMR0 with internal clock of 16MHZ. I used the wiring diagram from 4.12 EXAMPLE 10 **broken link removed** for a Pic16F887 wihch has the same pinouts as the PIC16F877.
I hope this helps somebody.
// LCD module connections
sbit LCD_RS at RB4_bit;
sbit LCD_EN at RB5_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// VARIABLES FOR LCD
char* txt1;
int count;
int shiftcount=0;
int tic = 0;
int msec=0;
// INTERRUPT VARIABLES
unsigned int seconds = 0, minutes = 0, hours = 0, days = 0;
char* weekdays[7] = {"MON","TUE","WED","THU","FRI","SAT","SUN"};
// INTERRUPT
if(T0IF_bit == 1){ // Check for interrupt flag
T0IF_bit=0; //Reset flag
counter++ ;
counter = 0 ;
seconds++ ;
if(seconds == 60){
seconds = 0 ;
minutes++ ;
if(minutes == 60){
minutes = 0 ;
hours++ ;
if(hours == 24){
hours = 0 ;
days++;
if (days == 7){
days = 0;
void main(){
//LCD
Lcd_Init(); // Initialize LCD
Lcd_Cmd(_LCD_CLEAR); // Clear display
Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off
Lcd_out(1,7,":");
Lcd_out(1,10,":");
//TMR0
OPTION_REG = 8;
GIE_bit = 1; //Enable Global Interrupt
T0IF_bit = 0; //Clear interrupt flag
T0IE_bit = 1; //Enable TMR0 interrupt
PEIE_bit = 1; //Peripheral Interrupt Enable bit
PORTA = 0;
TRISA = 0;
// Lcd_Chr(1,1,48+9); // // Only from 0 to 9. Need to use shift registerto
while(1){
//SECONDS
Lcd_Chr(1,12,48+(seconds % 10)); // seconds counter LSB
Lcd_Chr(1,11,48+((seconds /10) % 10)); //Seconds counter MSB
//MINUTES
Lcd_Chr(1,9,48+(minutes % 10)); // minutes counter LSB
Lcd_Chr(1,8,48+((minutes /10) % 10)); //minutes counter MSB
//HOURS
Lcd_Chr(1,6,48+(hours % 10)); // hours counter LSB
Lcd_Chr(1,5,48+((hours /10) % 10)); // hours counter MSB
//DAYS
Lcd_out(1,1,weekdays[days]); // days of the week
