pic16f877 + rs232 + matlab
a_sniper
Newbie level 3
Newbie level 3
hi every one
i am trying to write program to make communication between matlab and pic16f877
but when i tried to send string value from matlab to pic using "fprintf" in matlab and "gets" in ccs compiler it didn't work
although when i tried to send character from matlab to pic using "fprintf" in matlab and "getc" in ccs compiler it was ok
so can any one help me
and when i used virtual terminal for rs232 in Proteus instead of matlab it was ok
notice
i used in simulation Proteus 7 Professional
HTML:
#include <16f877.h>
#device adc=10
#use delay(clock=20M)
#byte port_a=5               // port_a address 5
#byte port_b=6               // port_b address 6
#byte port_c=7               // port_c address 7
#byte port_d=8               // port_d address 8
#byte port_e=9               // port_e address 9
#fuses HS
#use rs232(baud=9600,xmit=pin_c6,rcv=pin_c7,BITS =8,PARITY=n,STOP=1,ERRORS)
#include <stdlib.h>
#include <string.h>
char c;
float data;
float  volt;
int pwm1=0;
char vstr[10];
void io_set()
   set_tris_a(0xff);
   set_tris_b(0x00);
   set_tris_e(0xff);
   output_b(0x00);
////////////////////////////// control /////////////////////////////////////////
void read_analog()
   while(true)
         if(kbhit())
            gets(vstr);
            pwm1=atoi(vstr);
            output_b(pwm1);
            break;
void main()
   setup_adc_ports(A_ANALOG);      // PA all a/d ports and Vdd ref+  Vss ref-
   setup_adc(ADC_CLOCK_DIV_32);
   io_set();
   while(true)
      read_analog();
and matlab code
HTML:
s=serial('COM1');
set(s,'BaudRate',9600);
set(s,'DataBits',8);
set(s,'Parity','none');
set(s,'StopBits',1);
set(s,'FlowControl','none');
fopen(s);
x=input('enter number \n');
ch=num2str(x);
fprintf(s,'%s',ch);
fclose(s)
delete(s)
clear s
