pic16f876 help plzzzzzzzzzzzzzzzzzzzzzzzz
suwaii
Member level 4
Member level 4
I PROGRAMM PIC16F876 BY JDM PROGRAMMER AND I Successful in that
the programme is to make porta and portc have vlue=5f and i connect MCLR/Vpp to +5V and ocs1 & ocs2 to crystal 4MHZ with 2 capacitor 22pf
and Vss(pin#8 &pin#19 to GND and pin#20 to +5V
but i do not get any thing
what is the problem why porta and portc is not have value "5f"
i try to use RC ocsillator R=5k and C=22pf still the same any one tell why and
how can we do that
Try to play with CONFIGURATION WORD in your program/programmer.
You need to set:
HS - for oscillator.
BOR disabled.
WDT - disabled.
Connect your crystal and capacitors. Next, you need to look by oscilloscope to pin 10 (OSCOUT) there must be some oscillation (0.3 - 1.0 V).
still i do not get any thing ....may be the problem from code can any one tell me what is the problem of the code :
LIST p=16f876, R=DEC
#include "p16f876.inc"
org 0
movlw 0x00
movwf TRISB
movwf TRISA
movwf TRISC
movlw 0x0F
movwf PORTA
movwf PORTB
movwf PORTC
circle goto circle
end
i convert this programme to hex using MPASM then i test it by pic16simulator i get
PORTA,PORTB,PORTC =0F
and i use again jdm circuit and ic-prog to programe the pic and i successful in the that but when i test my pic with 4mhz crystal and Vpp/mclr=+5v i do not get any thing pleas help me:D
Hi!
Well the problem is obvious, you are not switching the banks.The registers in PIC Microcontrollers are banked try to compile this
org 0x00
bsf STATUS,RP0
MOVLW H'06' ;porta all digital io
MOVWF ADCON1
movlw 0x00
movwf TRISB
movwf TRISA
movwf TRISC
bcf STATUS,RP0
movlw 0x0F
movwf PORTA
movwf PORTB
movwf PORTC
circle goto circle
end
in addition to this also be careful about the fuse settings.
one more point is that porta is also the analog input port therefore it is necessary to configure it for digital input/output by writing to the ACON1 register.
Best of Luck
Regards.
