PIC16F84A to DB9 without MAX232
bangunprayogi
Newbie level 5
Bandung, Indonesia
pic16f84 max232
Hi, I have quetions about serial communication on PIC16F84A microcontroller. Is the PIC16F84A not need the MAX232 level converter? And how the configuration of that connection? I want the example of the schematic.
pic16f84a max232
Since the PIC16F84A does not have a serial port, you will drive the TxD pin and sample the RxD pin in SW. If you invert the levels in SW, you can connect the PIC to the RS-232 using just two resistors: about 220~330Ω in series with TxD and RxD.
Tried, tested and true.
Or, use two 74HC04 gates. Use 330Ω in series with TxD and 47-100kΩ in series with RxD. Now you do not need to invert the signals in software. This will also work with dedicated serial ports.
max232 con db9
As you see, you can't connect PICs Rx and Tx directly to DB9. So, the question is, why don't you want to use MAX232 (or its no-external-capacitors version MAX233)?
You do need some sort of circuit to invert these signals anyhow..
Regards,
IanP
