[SOLVED] PIC16F84A --> PIC16F819 FOR LCD.
Shinnster
Member level 4
Malaysia
Okay so I tried to use PIC16F819 to replace PIC16F84A,
but for some reason, PIC16F819 will not display Hello World.
Any particular reason?
Things to note:
I disabled MCLR, so I just left that pin as it is.
I use XT (4MHz) External so I config'ed that.
What other things I should take note?
Worth checking all the config paramenters - but probably the commonest error is that if you are using Ports RA0 -RA4 for your lcd, your must select them for Digital I/O by means of ADCON1 as the chip defaults those ports to analogue at power on.
Does your lcd show a row of black blocks across the top row - that usually means the lcd is ok, but your progam is not running.
You could also try using the 4meg internal oscillator incase you have damaged or have a faulty xtal.
    Shinnster
Oh, thanks for that.
Yeah the LCD was showing a row of black blocks.
I did try the 4Mhz internal oscillator. Wanted a similar circuit to F84A.
What is Write Enable for?
No, different, I'm talking about PIC16F819.
In the Configuration, WRT.
Nvm about it =]
Not something I have used, but on your chip I think its turned on to allow the program to change its own program code while it is running !
See page 30 section 3.7 for details.
In a word, just let it use the default WRT config value as it not a function you will really want to use just yet.
