kushal nandanwar
Full Member level 3
I have uploaded my PIC16F72 code for interfacing 4 Analog channel, but ADC not reading any data from output channel, I have used 1.8MHz crystal, required 1KHz PWM with varying duty cycle, pls help me.
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 #include <htc.h> #include<pic.h> #include <stdio.h> void DELAY( void ); #define DATA ADRES #define _XTAL_FREQ 1800000 unsigned int Power,Power1, battery_Power; unsigned int Voltage, Current, battery_Voltage, battery_Current, DUTY =0x00; #pragma config WDTEN = OFF #pragma config OSC = XT void main(void) { CCP1CON = 0x00; PR2 = 0x1D; /* Set Time Period Value */ TRISC=0x00; /* Set RC as an output pin */ PORTC=0x00; TRISA =1; /* Set RA as an INPUT pin */ PORTA =1; T2CON = 0x03; /* 16 Prescalers Timer 2 */ CCP1CON = 0x0C; /* PWM Mode */ CCPR1L = DUTY; TMR2ON = 1; /* Timer 2 ON */ while(1) /* infinit loop*/ { /* analog channel setting for first sample*/ /* analog channel setting for voltage*/ /* AN0 analog input for voltage*/ ADCON0 = 0b01000001; /* strat ADC */ ADCON1 = 0x00; /*define port A as an analog port*/ DELAY(); GODONE=1; /*begin conversion */ while(GODONE == 0); /* Wait for the conversion to end*/ Voltage = DATA; /* Save voltage in ADRESH as Voltage_Step_Number*/ /* analog channel setting for current*/ /* AN1 analog input for current*/ ADCON0 = 0b01010000; /* strat ADC */ ADCON1 = 0x00; /*define port A as an analog port*/ ADON=1; GODONE=1; /*begin conversion */ while(GODONE == 0); /* Wait for the conversion to end*/ Current = DATA; /* Save voltage in ADRESH as Voltage_Step_Number*/ if((Current >0) && (Voltage > 0)) { RC1=1; /*machine ON/OFF pin*/ RC3=1; /* program running indicator LED */ RC0=RC2; /* BATTERY CHARGER INDICATOR */ Power=Voltage*Current; /* POWER CALCULATION */ /* analog channel setting for second sample*/ /* analog channel setting for voltage*/ /* AN0 analog input for voltage*/ ADCON0 = 0b01000000; /* strat ADC */ ADCON1 = 0x00; /*define port A as an analog port*/ ADON=1; GODONE=1; /*begin conversion */ while(GODONE == 0); /* Wait for the conversion to end*/ Voltage = DATA; /* Save voltage in ADRESH as Voltage_Step_Number*/ /* analog channel setting for current*/ /* AN1 analog input for voltage*/ ADCON0 = 0b01010000; /* strat ADC */ ADCON1 = 0x00; /*define port A as an analog port*/ ADON=1; GODONE=1; /*begin conversion */ while(GODONE == 0); /* Wait for the conversion to end*/ Current = DATA; /* Save voltage in ADRESH as Voltage_Step_Number*/ Power1=Voltage*Current; /* N+1 POWER CALCULATION */ /* analog channel setting for batter voltage*/ /* AN2 analog input for voltage*/ ADCON0 = 0b01001000; /* strat ADC */ ADCON1 = 0x00; /*define port A as an analog port*/ ADON=1; GODONE=1; /*begin conversion */ while(GODONE == 0); /* Wait for the conversion to end*/ battery_Voltage = DATA; /* Save voltage in ADRESH as Voltage_Step_Number*/ /* analog channel setting for batter current*/ /* AN3 analog input for voltage*/ ADCON0 = 0b01011001; /* strat ADC */ ADCON1 = 0x00; /*define port A as an analog port*/ ADON=1; GODONE=1; /*begin conversion */ while(GODONE == 0); /* Wait for the conversion to end*/ battery_Current = DATA; /* Save voltage in ADRESH as Voltage_Step_Number*/ battery_Power=battery_Voltage*battery_Current; /* POWER CALCULATION FOR REFERANCE */ /*comparision loop for changing duty cycle*/ /* Compare Voltage and power to previous and increment/decrement DUTY cycle*/ if(Power1 >Power ) { DUTY++; DELAY(); } else if (Power< Power1) { DUTY--; DELAY(); } } else { RC1=0; /*machine ON/OFF pin*/ DELAY(); } } } void DELAY () /*delay program*/ { unsigned char cnt = 4000; // Delay Cycle to achieve delay while(--cnt != 0); // Delay Timing is approximately 3 usec per loop }
